Clutch Cable Snapped. Need Help!
Old Jul 1, 2006 | 04:49 PM
D'PEXi's Avatar
Default Clutch Cable Snapped. Need Help!
So my clutch cable snapped today, and I'm getting a replacement tomarrow.
My car is stuck on a small street in a ghetto side of the city and I'm afraid it's going to get jacked up. I had a friend help me remove my subwoofers, amps, intake, deck, and unhooked the battery (not that it could drive anyway, it's stuck in neutral). Oh, and I even took my shift ****. :D
All I want to know is, HOW do I install the cable? Any sites?
Any details on the whole, cable to pedal would be greatly appreciated!
It's an 88 CRX Si.
D16A6
Thanks.
Old Jul 1, 2006 | 04:57 PM
EHondaD6's Avatar
Default Re: Clutch Cable Snapped. Need Help! (Dpexi)
its easy...
also if you want you could start the car in gear and force the gears in so you could drive it outta there....
put it in first and start the car itll roll while trying to start...give it some gas and it should go....i wouldnt leave my car there at all....or tow it if your that concerned...
Old Jul 1, 2006 | 04:58 PM
SVOboy's Avatar
It hooks over the top of the pedal, just hooks over, runs through the hole in the firewall, and then you slip it over the lever and into the holder and tighten down the little ****.
Old Jul 1, 2006 | 06:00 PM
Hamstr323's Avatar
Default Re: Clutch Cable Snapped. Need Help! (HondaED6)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by HondaED6 &raquo;</TD></TR><TR><TD CLASS="quote">its easy...
put it in first and start the car itll roll while trying to start...give it some gas and it should go....i wouldnt leave my car there at all....or tow it if your that concerned...</TD></TR></TABLE>
we did this but got it started in second gear & drove it home
Old Jul 1, 2006 | 07:11 PM
D'PEXi's Avatar
Thanks guys. So I got my car home now, since it was parked about 10 blocks away.
More info please Thanks again guys. Much appreciated...
Tapout383
Nov 11, 2009 07:05 PM
efrex
Nov 5, 2005 06:45 PM
jon1fox
Sep 23, 2005 04:21 AM
CRX_Control
19
Nov 11, 2004 12:31 PM
coot_er
15
Sep 12, 2004 08:00 PM
