LS 91 crx Si Swap Guide? *Searched*
Old Jul 1, 2006 | 12:07 PM
JDM Panda's Avatar
Default LS 91 crx Si Swap Guide? *Searched*
Searched and didn't Have any luck, Anyone have a link saved or anything?
Old Jul 1, 2006 | 05:29 PM
jacoop86's Avatar
Default Re: LS 91 crx Si Swap Guide? *Searched* (JDM Panda)
same as any other b series swap, check the faq on the top of the ef forum page or here: https://honda-tech.com/zerothread/1508680
also try searching for b16 or other b engines.
Old Jul 1, 2006 | 05:37 PM
Bjorn20's Avatar
how hard did you search? theres shitloads of swap guides for b16 which is basically the same as the ls minus some wiring.
http://www.crxresource.org/mod...d=134
Old Jul 1, 2006 | 08:08 PM
JDM Panda's Avatar
Default Re: LS 91 crx Si Swap Guide? *Searched* (Bjorn20)
Well I wasnt Sure about the wireing that was my only big question I didn;t know if it was wired the same way
Old Jul 1, 2006 | 08:37 PM
davens's Avatar
There are several ways to the wiring. I'm going to tell you the easiest.
Whatever B18a/b you've got, use all obd-0 components.
Get a 90-91 teg pr4 ecu and distributor. It's all plug-in.
Use your CRX Si wiring harness.
The CRX wiring harness is 99% plug-in. You may have to extend one wire or change one plug, but that's it.
Use your stock CRX Si injectors. They all plug in because, duh, you're using the stock Si harness.
That's it...
Old Jul 2, 2006 | 06:32 AM
JDM Panda's Avatar
Default Re: (davens)
AHH You rock thanks ^^
aps13
Dec 13, 2010 04:24 PM
jslater2306
Dec 7, 2007 07:04 PM
88crx1589
Jul 7, 2005 08:19 AM
wherethefocowe
May 25, 2005 06:23 PM
