Fuel injector cleaning
To remove the gas cap it takes no less then 7 steps.
1) search the car for the small lever with the gas door on it
2) stair at it and figure out how it works
3) pull the lever up
4) hear a noise and look around the inside of the car for were the noise came from
5) look out side the car, no the other side
6) Turn the gas cap clock wise... ok now try the other direction
7) place gas cap on handy dandy gas cap holder
You're done.... pour it in and close gas cap.
[Modified by AssPenny, 6:51 PM 4/18/2002]
Oh, you wana do that... no way to realy clean it yourself unless you have an ultra sound cleaner. There are companies out there that will do it. To remove them, remove the fuel rail, unclip the injector plugs, pull injector out of intake header... nutting to it.
Craig - Who's not sure if he missed anything, but it's pretty damn easy.
one of the techs at TRS told me "you can tap them on the table and **** will come out"..... ???? i dunno
do you need to "pinch off" the lines first??? so the fuel doesn't spray out...
Na, just leave the car off and the gas cap open for about 20 minutes... that should let most of the gas out of the lines near the motor. Little tip i learned from Mike K.
Craig - Who wonders where the hell Mike K has been.
lifesk8err
Aug 5, 2011 04:54 AM
scarcha
Jan 13, 2011 12:25 PM
MidwestCivic
13
Jul 17, 2007 05:31 PM
