how do i clean vtec solenoid?
Old Jul 1, 2006 | 10:12 AM
Fat Chick Magnet's Avatar
Default how do i clean vtec solenoid?
How do i clean it? Does the vtec solenoid come off? Do i use some special cleaner or just use a towel? someone explain to me in details before i do something wrong.
Old Jul 1, 2006 | 10:17 AM
aziz93's Avatar
Default Re: how do i clean vtec solenoid? (dc2rtek)
unbolt it, pull it off, and see if the screen it dirty if so then clean the screen out
Old Jul 1, 2006 | 11:10 AM
Default Re: how do i clean vtec solenoid? (aziz93)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by aziz93 &raquo;</TD></TR><TR><TD CLASS="quote">unbolt it, pull it off, and see if the screen it dirty if so then clean the screen out</TD></TR></TABLE>
it wont mess anything up right if i unbolt it?
Old Jul 1, 2006 | 11:40 AM
94integragsr's Avatar
Banned
no it wont but oil will leak out
Old Jul 1, 2006 | 11:44 AM
PatrickGSR94's Avatar
Community Builder
Community Influencer
Active Streak: 60 Days
Default Re: how do i clean vtec solenoid? (94integragsr)
yes make sure you put a bunch of rags under it... I didn't and now I have a big mess all over my garage floor.
I just replaced my screen with a brand new one a few weeks ago... old one had never been changed or cleaned I'm sure, and it was CRUSTAY! The gasket was very brittle.
Old Jul 1, 2006 | 11:59 AM
aziz93's Avatar
Default Re: how do i clean vtec solenoid? (PatrickGSR94)
[QUOTE=PatrickGSR94]yes make sure you put a bunch of rags under it... I didn't and now I have a big mess all over my garage floor. QUOTE]
yeah what he said. opps
add oil when done
Old Jul 1, 2006 | 02:59 PM
F$#% i over tighten one of the bolts and it broke!!!!!!!!!!!!!!!!!!!! what can i do about that?
Old Jul 2, 2006 | 08:00 AM
aziz93's Avatar
Default Re: (dc2rtek)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by dc2rtek &raquo;</TD></TR><TR><TD CLASS="quote">F$#% i over tighten one of the bolts and it broke!!!!!!!!!!!!!!!!!!!! what can i do about that?</TD></TR></TABLE>
not funny but lol, sunsabitch
add oil to the proper level start the car and see if it leaks. If not then you should be good but get it fixed sooner then later! if just the head of the bolt snapped off then take the vtec selinoid back off and get some vise grips and lock onto the shaft of the bolt that is still sticking out and unscrew it. if it broke off by the base of the head to where you cant grab it then you have to use a tap thing to get it out basically to drill a hole in the center of the bolt then you screw in a reversr threaded screw into the hole and that unscrew the bolt. call your machine shop or go buy your own set of bolt retractors. not sure of the exact name. good luck and with those 10mm bolts that are on the head or engine compartment, just tighten till it stops(w/lube) then just give it a 1/4 of a turn
Old Jul 2, 2006 | 11:06 PM
i got the bolt out and replaced it
em1gangsta
17
Mar 19, 2008 09:38 AM
ophdehEEzY
Mar 19, 2007 03:10 PM
porter
Feb 15, 2007 02:15 PM
aclw2
Mar 22, 2004 10:30 PM
guywitahatch316
Sep 2, 2003 10:18 PM
