how do i get my timing bak the way it should be
Old Jul 1, 2006 | 09:32 AM
efyou's Avatar
Default how do i get my timing bak the way it should be
me and my dad did a headgasket on my car last weekend, and when we were taking everything off, it totally slipped my mind to mark the cam gears or what not for the timing belt placement. so now it sounds like ***. is there any easy way to match everything up again? we did make sure the cams were TDC (otherwise it probably wouldnt have started) so im that far, or do i jus have to do some trial and error on adjusting the belt?
Old Jul 1, 2006 | 09:47 AM
charlee's Avatar
Default Re: how do i get my timing bak the way it should be (efyou)
what engine do u have?
Old Jul 1, 2006 | 09:48 AM
efyou's Avatar
Default Re: how do i get my timing bak the way it should be (charlee)
b18a
Old Jul 1, 2006 | 09:56 AM
Redline130's Avatar
With the cams at TDC, check to make sure that the crank is also at TDC. There is a mark on the crank pulley that will line up with pointer on the timing belt cover. Also, did you check your ignition timing as well?
Old Jul 1, 2006 | 10:00 AM
efyou's Avatar
Default Re: how do i get my timing bak the way it should be (Redline130)
ignition timing is fine. i know the belt is off some teeth, it has to be, this thing sounds like total *** man, and its not loose.
Old Jul 1, 2006 | 10:07 AM
Redline130's Avatar
Are the two cams lined up? Unfortunately, sounds like you will need to re-do the whole timing belt set up and get everything lined up.
BitterTrigger
Oct 15, 2017 04:26 PM
f20beme
Apr 13, 2015 04:34 AM
jdmthug
Aug 22, 2009 07:09 AM
turboedsupe
Sep 19, 2008 04:32 PM
Thrillhouse
Aug 9, 2004 02:47 PM
