Crossing Clusters
Well, I've got a 91 hatch DX (IOW, no tach) and an 88 Rex Si (IOW...it's got a tach). I wanna get the tach in the civ, and eventually put a JDM cluster in the rex...so I checked today to see if it was direct bolt in. Well...it bolted in...but the electrical was ALL wrong, and alas, no working tach.
Anyone know what I can pull a cluster from to be direct bolt in? Or shoot me a wiring diagram? I'd prefer direct bolt-in...
When you figure out what you need let me know. I have a few 88-89 + 90-91 cluster parts around.
Off the top of my head, did you try swapping the green wiring panel on the back? Did your non tach green panel have leads for a tach?
This should be your answer. Just repin your plugs to match the crx cluster wiring.
https://honda-tech.com/zerothread?id=709958
Chimpo, if the 90-91 tach cluster is direct plug-and-play, I might take one of your hands...how much are you asking?
CRX, dude, that is a CLEAN swap with the new Si cluster. Your information helped tremendously. I may consider the 99 Si swap for the CRx. As for the civic (the car I wanna get a tach in) it'll be going AutoCross, so I don't wanna spend the money for all that. However, the CRx may get that swap...
And to he who said search...I did a little searching, but didn't see quite what I was looking for, but I KNEW it was out there. CRX found it. I'd seen that page in the past, and just couldn't find it.
Thanks, everyone!
Thanks, everyone!
Sorry, I left out a response or two. No, I hadn't tried swapping the green boards in the back of 'em, can this be done without damaging anything? I hadn't even thought to do that.
No, it didn't have a tach lead that I saw...I'll look again next time I pull it all out...probably be on the fourth.
Thanks again, everyone
I couldnt find it by searchign either, but luckily, I had it in my favorites. I swapped a 94 gsr cluster into my crx. Looks great and matches the gsr cd player perfectly. I'm only having problems getting my speedo working, but thats just a simple wiring issue I think...or my electronic vss is shot...
civicminded93
Jan 5, 2012 09:48 AM
