Gas cap holder
I've seen people complain that their RSX doesn't have a gas cap holder.
Mine does.
It's a groove in the plastic of the gas door which allows you to slot in the small plastic tube with the ball on the end of it which is attached to the gas cap.
Do other RSXs not have this or something?
gi.
Mine does.
gi.
The first few thousand RSXs didnt come with the gas cap holder. Mine is about the 15,xxx one made, and it didnt have one for some reason. I had to call Acura Client Services in order to obtain one.
The gas cap has little "slits" in the plastic around its perimeter. You can easily use these to hold the cap on the inside edge of the gas door. If you insert the edge of the gas door into two of the slits, it will stay put.
crxaddikt
Dec 6, 2013 10:07 AM
