hatckback fan dont work!!
can anyone up in here know why my fan wont turn on automatically?cause the fan works when i connect it direct to the battery,but i t just wont work,can anyone help.thanx in advance.
Relay's and/or fuses. Keep in mind the age of your car...the wiring MIGHT have a bad spot.
Get a line-tester, or learn how to use a voltmeter as well as some better english.
Good luck.
Oh, you can check a Haynes or Helms manual...they have good trouble-shoot guides.
Good luck.
on which car is this, if it's an eg, check the connections right by the thermostat gauge, that little sensor there is for the fan, and on a ef check the rear sensor on the block, it's a yellow and green wire I believe and it's got a big plastic rubber piece that covers it.. check those wirings in those areas..
