GS-R rattling noise
Old Jun 30, 2006 | 09:03 PM
jmoss1987's Avatar
Default GS-R rattling noise
I was driving my gs-r tonight and I started hearing a noise. It is like a rattling noise coming from right behind my motor. When I am driving down the road it sounds like something is scraping the ground, but there is nothing hanging down. I don't know what it could be. Anyone have a clue?
Old Jun 30, 2006 | 09:11 PM
CNSK's Avatar
Default Re: GS-R rattling noise (jmoss1987)
Make an attempt to figure it out yourself by jacking up the car and take a look at it before creating a thread. No know can really give you a definite answer by your question.
Old Jun 30, 2006 | 09:13 PM
BLKGSR24's Avatar
heatshields around the cat could be rattling, or the exhaust downpipe could be the culprit. If it was coming from the front of the engine then it could also be the exhaust manifold heatshield.
edit: oh yeah is it a constant rattle or only at certain RPM's like 3000-3500?
Old Jun 30, 2006 | 09:23 PM
jmoss1987's Avatar
Default Re: (BLKGSR24)
First of all why are there people who take tiume to say smart comments like the first guy. What a jerk.
No it is a constant rattle throught all rpms. Could it be the timing belt? Thanks for your comment though.
Old Jun 30, 2006 | 09:31 PM
Teg_Your_It's Avatar
Default Re: (jmoss1987)
How would a timing belt rattle? Did you mean it's making a taping sound from the engine like somepart is touching something when you gas the car?
If it is a rattling sound, then something is not tighten all the way.. Air is escaping so it rattles.. check your exhaust, intake manifold and so on where air can come out
Old Jun 30, 2006 | 09:33 PM
BLKGSR24's Avatar
If it's coming from behind the engine like you say then my guess would have to be something from the exhaust. Most likely the heatshields around the cat will break loose alittle to cause a metal on metal rattle.
Old Jun 30, 2006 | 09:42 PM
jmoss1987's Avatar
I just got 2 1/2 inch piping a magnaflow cat and a new resonator about a week ago. I had trouble with it vibrating my seats and stuff so I took it back yesterday and the mechanic had to put a rubber piece where the mounting brackets were. I guess I will just take it back to him and get him to look at it. Thanks for ur help.
Old Jun 30, 2006 | 11:00 PM
DC2 Mang's Avatar
loose filters in the cat
its a very common problem with honda's
Old Jun 30, 2006 | 11:54 PM
TRE_'s Avatar
Default Re: (DC2 Mang)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by DC2 Mang &raquo;</TD></TR><TR><TD CLASS="quote">loose filters in the cat
yep
Old Jul 1, 2006 | 12:24 AM
Zer0ne's Avatar
Default Re: (TRE_)
if it gets faster as your revs climb might wanna check if its a rod knock, i thought i had a heat shield problem at first and i just left it, but it got worse, now the knock is badddd
the_lude_01
Mar 24, 2009 03:46 PM
oldbeefcake
Aug 24, 2004 03:09 AM
2000tegGS-R
May 1, 2004 10:19 PM
[Race][666]
Sep 22, 2001 01:27 PM
