Want to Buy Want to Trade/Want to Buy
WTB: I got for 4k for a engine swap... What you got?
Old Jun 30, 2006 | 08:45 PM
SiViK-R's Avatar
Default WTB: I got for 4k for a engine swap... What you got?
I got 4k-4.5k(depends what I will get with it) for a engine swap...
Preferably something already built/has internal mods. DOHC only...
Let me see what you got.
Old Jul 1, 2006 | 01:40 AM
z24mike's Avatar
have a complete h22 swap off a 97 prelude female driven all legit no leaking, smoking, or knocking. 30 day guarantee engine, 5 speed trans, cables, harness, mounts, ecu, console, clutch resovoir and lines etc. for $3,300. All legit IM me if interested
Old Jul 1, 2006 | 09:41 AM
One day...'s Avatar
Default Re: WTB: I got for 4k for a engine swap... What you got? (SiViK-R)
i have a complete jdm h22a minus the wiring harness for $2000.00 obo
Old Jul 1, 2006 | 10:46 AM
A13sechatch's Avatar
where are you located
Old Jul 1, 2006 | 10:52 AM
SOHCwarrior's Avatar
http://www.hondamarketplace.co...age=1
Old Jul 1, 2006 | 04:43 PM
djbutler007's Avatar
i got a h22 swap complete from axels to harness, check my sig for more info
Old Jul 3, 2006 | 04:05 PM
Nsane1's Avatar
From: West Bakalakadaka St., Durka Durka Mohammed Gihad, WMDs
Default Re: WTB: I got for 4k for a engine swap... What you got? (djbutler007)
B18a1 from a 96 GSR that I'll let go cheap. And everything is included including ECU and even the a/c compressor.
Old Jul 3, 2006 | 07:59 PM
Smooth_Imports's Avatar
Default Re: WTB: I got for 4k for a engine swap... What you got? (Nsane1)
Block (Only 2000miles Yes 2000 miles on all parts)
99’ B18b1
Moroso oil pan w/ oil return bung & oil temp sensor bung
Stock Ls crank micro polished & balanced @ 8500rpms
ACL race main bearing & thrust washers
Clevitte H-series rod bearing
Eagle H-beam rods “ESP” w/ ARP rods bolts
Wiseco Pistons # K542m81 w/ file to fit rings
ACT HDSS Clutch & P-plate
Stock LS Flywheel
New Honda water pump
New Honda Oil pump
New Honda timing belt
ARP Head bolts
Every seal and gasket was replaced with True Honda parts
All sensors are in working condition
Block was assembled by Proformance Unlimited
Head (Only 2000 miles after rebuild on head)
99’ ls
Stock Honda head gasket
3 angle valve job
New Honda valve seals
New Honda valve guides
Crower dual stage valve springs
Crower titanium retainers
New Honda valve keepers
Stock LS cams
D-1 Cam cap
Stock Honda dizzy
Stock LS intake manifold
Stock LS fuel rail
B&M Fuel pressure regulator
NGK Plugs & Wires
Every Seal And Gasket was replaced with True Honda parts
Head was assembled by Proformance Unlimited
Tranny
99’ LS 60k miles
No grinds
Comes with linkage
Slave Cyl
Axles
All sensors are in working order
Misc
Will include OBD2 ECU Even though I highly recommend you running a real EMS system
P/S pump
Alt
Starter
Other misc items
[Looking to get $3500 for this OBO, No corners were cut when building this motor and no expense was spared. If you think what I’m asking is to high shoot me a PM with an offer please don’t ***** my post.
I so don’t wanna sell this unit but times are hard and I gotta do what I gotta do to survive
Motor is located in central Jersey 07702, I can ship and have really good rates on shipping. Pick up is more then welcome
Here are a few picks of the motor being built. Will post pic’s of motors current condition once it’s pulled
*Turbo no included but i for sale*
Old Jul 3, 2006 | 08:08 PM
95cxh22a's Avatar
Default Re: WTB: I got for 4k for a engine swap... What you got? (Smooth_Imports)
i will sell my whole car for not much more than that. complete gsr/itr swap, check sig.
Old Sep 8, 2006 | 04:23 PM
shivic's Avatar
ive got an obd I gsr swap complete in utah
http://hondamarketplace.com/zerothread?id=1746431
Old Sep 8, 2006 | 11:38 PM
im_poor's Avatar
Default Re: WTB: I got for 4k for a engine swap... What you got? (shivic)
I've got a complete 96 gsr swap if your interested stock w/ low miles. So. Cal too.
Old Sep 9, 2006 | 08:38 PM
asocallocal's Avatar
i have a 95 eg hatchback with a b16a1 swap built to ctr specs. 3500
tealchief
Sep 21, 2009 07:31 AM
t0p_sh0tta
Northeast (Sales)
Oct 2, 2007 04:09 AM
a1320addict
Aug 13, 2007 07:12 AM
mtetro99
Apr 5, 2004 08:53 PM
