overheating - bottom hose stays cold, do i need a new thermostat or just to bleed the lines
Old Jun 30, 2006 | 07:52 PM
oranginal's Avatar
Default overheating - bottom hose stays cold, do i need a new thermostat or just to bleed the lines
i need to have this fixed tomorrow i'm in a rush to get my car running......
i tried searching but i got too many things and i was just wondering if i needed a new thermostat or if bleeding the lines could work
thanks
update: got thermostat fixed and all is good.
Modified by oranginal at 11:27 PM 7/3/2006
Old Jun 30, 2006 | 08:31 PM
PrettyLude's Avatar
if the bottom hose is not hold, try a thermostat first
Old Jun 30, 2006 | 08:50 PM
bb_one's Avatar
Default Re: (PrettyLude)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by PrettyLude &raquo;</TD></TR><TR><TD CLASS="quote">if the bottom hose is not hold, try a thermostat first</TD></TR></TABLE>
If your car is overheating and the bottom hose is cold, it sounds like your t-stat is stuck shut. An oem t-stat is cheap anyway, so try that out first then bleed your system well.
Old Jul 1, 2006 | 03:10 AM
oranginal's Avatar
alrighty i'll le tya know what happens, thanks
edit: it was the thermostat, thanks
Modified by oranginal at 1:41 PM 7/6/2006
accord_2dr
Oct 1, 2007 06:06 PM
blinger
May 14, 2007 06:39 PM
snowblind7x
Feb 21, 2007 08:58 PM
importfanatic17
Jan 4, 2007 09:14 PM
BoostNEF
May 14, 2005 01:18 AM
