will this head work?
sorry no pics but i will try to describe it as best as i can. ok so i got a d15b7 and my head is a lil messed up so i went to j&j's and picked up a head but it is for a 6th gen it is still a sohc non v-tec but will it fit on my block with no problems and which head gasket would i use?? do i need a different timing belt?? also the spark plugs are more toward the front instead of the back. can anyone plz help. maybe you know which head i have.
not sure on head gasket and I believe 6th gen non-vtec are y7 and for the timing belt you get the belt for the cam i believe. I am sure someone will correct me if I am wrong.
B_Swapped93
Dec 17, 2012 03:07 PM
