Yea the uh car wont start.. i doint have a CLUE help
Last night i was leaving for work car worked FINE before leaving Tryed to start i got NOTHING Battery works.. lights/radio all come on FUEL PUMP Primes Swaped MAIN relays mine was fine....YOU CAN PUSH START THE CAR everything runs fine NO CELS
im at a loss replaced the starter it wont turn over.. Help me
pull a spark plug out.. see if your getting spark... is your car cranking? and just not turnign over.. pull the spark plug out... put it in the spark plug wire.. and crank the car.. groundit to see if you got some spark... letm e know
sounds like starter...either try knockin the starter while someone tries to start it...or replace...sometimes the starter weight will get stuck an just needs a couple hard knocks with a rubber mallet
Did you make sure to plug everything back in after you did the starter?
Make sure you connected the 12v cable from the battery and also the starter
signal wire?
I always like to bench test the starter b4 installing it.
signal wire?
Once again.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Slamaccord »</TD></TR><TR><TD CLASS="quote">Did you make sure to plug everything back in after you did the starter?
signal wire?
Check your engine grounds make sure they are tight.
signal wire?
Why dont you check your clutch pedal you have a starter interrupt maybe the pedal is not pushing the switch down or the switch is bad check your starter relays and starter fuse.
battery
just because your lights turn on dosent mean its got enough juice to turn the starter.
take the battery to vatozone, have them test it.
i just hotwired my starter (MAKE SURE CAR IS IN NEUTRAL W/ PARKING BRAKE ON). basically hook 12v from the battery to the starter signal wire (small one wire connector on the starter), if you do it with the key in the on position it should crank fine, w/ the key off it will turn over, but shouldnt fire up.
You should have three wires on your starter solenoid, one is power straight from the battery, the small one is the signal from the ignition, and the other should go in the starter motor. Just take a jumper wire and go from the positive post of the battery to ignition signal wire on the starter solenoid.
