Temperature Control Lever Doesn't Move
Old Jun 30, 2006 | 11:11 AM
BLacK FirE's Avatar
Default Temperature Control Lever Doesn't Move
Yea so like the title says it doesn't move. A friend of mine told me it was probably the thermostat, so I changed that and I still can't move it. I'm afraid to try and push real hard and end up breaking something. If it matters at all, I just put my head back on after having a broken exhaust valve and it worked fine before then.
Old Jun 30, 2006 | 11:22 AM
jared99's Avatar
Default Re: Temperature Control Lever Doesn't Move (BLacK FirE)
Are you talking about your temperature gauge? If so it sounds like your coolant temp sensor isn't plugged in on the side of the cylinder head.
Old Jun 30, 2006 | 11:25 AM
Dforce's Avatar
That's what she said!
Default Re: Temperature Control Lever Doesn't Move (jared99)
^^^^^^^^^sounds right!
Old Jun 30, 2006 | 11:38 AM
BLacK FirE's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by jared99 &raquo;</TD></TR><TR><TD CLASS="quote">Are you talking about your temperature gauge? If so it sounds like your coolant temp sensor isn't plugged in on the side of the cylinder head.</TD></TR></TABLE>
No not the temp guage. On the climate control, to control the hot and cold air coming out of the vents. I can't move that.
Old Jun 30, 2006 | 12:25 PM
Dforce's Avatar
take off the climate control and check the metal wire running from the switch to the heater box.
Morbius
Nov 12, 2008 06:22 PM
aries331
Dec 19, 2007 06:38 PM
xkrntamax
Jan 2, 2006 12:14 PM
mz3bo
Oct 11, 2003 08:50 PM
