5th gens with coilovers please post
Old Jun 30, 2006 | 09:30 AM
budget's Avatar
Default 5th gens with coilovers please post
installed coilovers, adjust the height from the very bottom/top barely changes. the fronts adjust fine but both of the rears barely change from me having it at the lowest setting to the highest setting.
-i put the coil with the longer sleeves in the rear
the coilovers cam with some black o-rings they are about the size of half dollars. one is thick, other is decently think and other is pretty thin. what are these for and what do they do?
Old Jun 30, 2006 | 06:37 PM
thaiswirls's Avatar
Default Re: 5th gens with coilovers please post (sackNsave)
the big O rings go between the 2 adjusters
the bigger springs go in the rear
the smaller springs go in the front
as far as the part that you raise or lower the ride height those were pretty much the same size for me.
when done correctly the rear end should look lower then the front its just how it ends up. the rear wheel wells are cut small then the front if i'm correct
did you cut the cushion thats between the damper and the gold ring at the to of the damper?? your supposed to cut that to leave about 1" of cushion?
i'll post pics of my lude tomorrow when i get a chance so you can compare
Old Jun 30, 2006 | 09:11 PM
budget's Avatar
Default Re: 5th gens with coilovers please post (thaiswirls)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by thaiswirls &raquo;</TD></TR><TR><TD CLASS="quote">the big O rings go between the 2 adjusters
i'll post pics of my lude tomorrow when i get a chance so you can compare</TD></TR></TABLE>
yeah i cut the bumpstop and left about an inch on the fronts and rears
ep3man
Jun 6, 2008 05:11 PM
firemanG
Suspension & Brakes
Jan 29, 2008 04:09 AM
budget
Suspension & Brakes
12
Jul 3, 2006 08:46 AM
thatbluecrx
13
Aug 5, 2005 11:50 PM
AnitRiceSuperStar
Jan 22, 2004 03:02 PM
