Which badge is correct for my del sol?
Old Jun 30, 2006 | 08:18 AM
Nate.Hamm's Avatar
Default Which badge is correct for my del sol?
Alright, i have gotten the cr-x del sol badge and both a vgi and a vxi badge. I need to know which one is correct for my 95 white si del sol. I have tried searching several times with no luck.
Old Jun 30, 2006 | 08:27 AM
Del Sol SiR's Avatar
Default Re: Which badge is correct for my del sol? (Nate.Hamm)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Nate.Hamm &raquo;</TD></TR><TR><TD CLASS="quote">Alright, i have gotten the cr-x del sol badge and both a vgi and a vxi badge. I need to know which one is correct for my 95 white si del sol. I have tried searching several times with no luck. </TD></TR></TABLE>
vgi... http://gtracelab.www6.50megs.c....html
Old Jun 30, 2006 | 08:53 AM
Nate.Hamm's Avatar
Default Re: Which badge is correct for my del sol? (Del Sol SiR)
i also got a few other decals in japanese, i was woundering if there was a post on the proper placement of them.
a srs part # 77871-sd4-n80
anouther one i dont know what its for part # 17669-sd4-z50
i think this one is for the abs i dont know which car its for either 57079-sr3-000
the last one i see it says a b16a engine on it 87533-p30-j01
thanks for your help so far.
Old Jun 30, 2006 | 09:01 AM
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Nate.Hamm &raquo;</TD></TR><TR><TD CLASS="quote">i also got a few other decals in japanese, i was woundering if there was a post on the proper placement of them.
thanks for your help so far.</TD></TR></TABLE>
the srs n' abs i believe are in the engine bay or under the hood, i took mine off otherwise I'd show you where they were mounted from Honda. where are your current abs n' srs decals @? if you don't have it, i wouldn't put them on, resell them on ebay
Old Jun 30, 2006 | 09:15 AM
Nate.Hamm's Avatar
yeah i have the one under the hood i was just checking to see if that was the proper place for the jdm one. as for the other decals is there a way to find out what thouse are for?
BenSol
15
Jun 20, 2006 10:25 PM
b18c5-EM1
Jan 30, 2005 07:06 AM
Slvr_CRX
Jul 14, 2004 08:48 PM
