vibrating frontend
Old Jun 30, 2006 | 07:05 AM
fbankins's Avatar
Default vibrating frontend
frontend vibrates when it get up to 55-60.....changed tie rods enter and outer 89 honda accord lxi
Old Jun 30, 2006 | 07:13 AM
Ross 2.0's Avatar
In a Junkyard near you.
did you check the balljoints?
Be sure the tires are balanced and there is no damage to the tires
Old Jun 30, 2006 | 07:14 AM
fbankins's Avatar
Default Re: (MooGoCow3)
replaced ball joints upper and lower and balanced tires and align
Old Jun 30, 2006 | 07:16 AM
Ross 2.0's Avatar
mine does the same thing.
Have you made sure the struts are good? Give the front a good hard shove down on the front and see how many times it bounces after you let go
Old Jun 30, 2006 | 07:17 AM
fbankins's Avatar
i think it might be my rack????? My accord is lowered
Old Jun 30, 2006 | 07:20 AM
Ross 2.0's Avatar
is there still freeplay when you have the front wheels off of the ground? Or in the steering wheel? Also you had a front end alignment didn't you?
Post some pictures of it!
(post carefully you only have 5 posts untill your off of trial)
Old Jun 30, 2006 | 07:27 AM
fbankins's Avatar
It's going to take me little because I'm at work and the car is home
Alpaca
Jun 6, 2019 04:40 PM
RichieHHix62
Feb 5, 2018 12:55 PM
Ed 341
Aug 14, 2006 04:02 PM
fbankins
Suspension & Brakes
Aug 8, 2006 07:03 PM
sikcrx80
Aug 25, 2003 01:52 AM
