question about LS turbo
Old Jun 30, 2006 | 06:49 AM
jweezy225's Avatar
Default question about LS turbo
I've been driving around my stock 94 LS for about two years and now Im thinking about getting a small greddy turbo kit in the future. I already know that the max it could produce would probably be 250whp and thats all I'd want just for fun daily driving; but anyway what I'm asking is... prior to buying the turbo kit, could I build the internals of my motor first? I read that the greddy kit was made based off stock LS engines... If I wanted to build the motor before getting the turbo, what would you recommend I do?
Old Jun 30, 2006 | 06:52 AM
Azn Kenny's Avatar
Turbo cams, upgraded valvetrain, forged pistons and rods, Cometic headgasket, ARP head studs, sleeves, etc.
Real question is how much do you have to spend?
Old Jun 30, 2006 | 06:57 AM
jweezy225's Avatar
Default Re: (LS-N)
I have whatever money needed if I save for it, so I could buy/install turbo cams before having the turbo actually installed? Out of the things you listed, what is actually needed rather than just good to have
Old Jun 30, 2006 | 07:24 AM
H23 Power's Avatar
Default Re: (jweezy225)
none of that is needed. just get a greddy kit and an intercooler to go with it and you'll be fine. to get to 250 whp you'll probably want a good engine management system, but the stock motor will be fine.
Old Jun 30, 2006 | 08:58 AM
yee SERIOUS's Avatar
greddy kit and a tune with hondata or crome will make a great street car.
Old Jun 30, 2006 | 09:14 AM
jweezy225's Avatar
Default Re: (undercoverdc2)
Oh okay, I see... well if I wanted to produce more power, would upgrading the internals of the engines do much? Or would I need a bigger turbo at that point?
Old Jun 30, 2006 | 09:37 AM
crix868's Avatar
A bigger turbo could take longer to spool but the faster it spools the more stress on the motor, which in that case you would want to build your internals. i ran a custom kit on my LS with a Precision GT35 dual Ball Bearing which hit full boost at 2k rpm with stock internals which handled it without tuning for like 6 months. upgrading the internals would allow you to turn up more boost for more power b/c going low compression internals would allow the motor to handle the power. good luck on that and have fun
Old Jun 30, 2006 | 10:33 AM
jweezy225's Avatar
Default Re: (crix868)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by crix868 &raquo;</TD></TR><TR><TD CLASS="quote">A bigger turbo could take longer to spool but the faster it spools the more stress on the motor, which in that case you would want to build your internals. i ran a custom kit on my LS with a Precision GT35 dual Ball Bearing which hit full boost at 2k rpm with stock internals which handled it without tuning for like 6 months. upgrading the internals would allow you to turn up more boost for more power b/c going low compression internals would allow the motor to handle the power. good luck on that and have fun </TD></TR></TABLE>
oh okay, thanks.. thats a really good answer how much psi were you running on that setup?
Old Jun 30, 2006 | 11:03 AM
crix868's Avatar
if your running on stock internals i'd say tune it at 7psi for safety....jus remember try an use a turbo that will stay in vaccum while cruising yet will give you the right power you need once you hit full throttle
Old Jun 30, 2006 | 11:34 AM
jweezy225's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by crix868 &raquo;</TD></TR><TR><TD CLASS="quote">if your running on stock internals i'd say tune it at 7psi for safety....jus remember try an use a turbo that will stay in vaccum while cruising yet will give you the right power you need once you hit full throttle </TD></TR></TABLE>
would a greddy turbo kit do that? what hp would 7psi produce?
Old Jun 30, 2006 | 04:35 PM
Adambomb's Avatar
I believe they should post what HP gains you'll receive on the website you're buying the turbo kit from.
For daily driving though, you wouldn't need to get stonger internals unless you plan to push up the boost in your car. I'm running Rev Hard on a '00 stock ls at 8 psi.
Just get a good tune and you'll be set for a while.
Old Jun 30, 2006 | 04:48 PM
jweezy225's Avatar
Default Re: (AdamO)
oh ight cool, what do u redline at on that setup? or do u not rev any higher with boost and stock internals
Old Jun 30, 2006 | 05:00 PM
H23 Power's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by jweezy225 &raquo;</TD></TR><TR><TD CLASS="quote">oh ight cool, what do u redline at on that setup? or do u not rev any higher with boost and stock internals</TD></TR></TABLE>
keep the stock redline.
honestly the greddy kit will allow you to run about 15 psi max before the turbo gives up. there's some people making 300 whp here on stock internals, but I'm not sure the greddy turbo will get you there, but it may be close. about the only internal mod that would give you more power would be some turbo specific cams.
Old Jun 30, 2006 | 05:48 PM
jweezy225's Avatar
Default Re: (H23 Power)
oh okay, so running like 10 psi with stock internals would be safe? and with turbo specific cams would be safer? turbo would definitely decrease the reliability of my motor right
Nexx's Avatar
Go here.
Also. Avoid the Greddy Kit. You will not produce 250whp on a b18b with only 7psi. I recommend drag kits + a good tune if you want to keep things simple... else just go custom and package your turbo setup to your goal.
Old Jun 30, 2006 | 06:18 PM
jweezy225's Avatar
Default Re: (Nexx)
stay away from the greddy kit? why? you think building a turbo to produce 250hp would be cheaper than the greddy kit?
Old Jun 30, 2006 | 08:42 PM
Spec R's Avatar
I'm rocking basically a greddy kit on my LS....i think 250whp would be feasible given the right upgrades...but by then, it would have equalled the price of a non-CARB exempt kit.
at 6 psi....my b18b1 is making about 9whp/9wtq per pound of boost....with the stock 2" Greddy downpipe, 2.25 exhaust, 2.25 cat...if i get an e-cutout and up the boost...i'm very confident i can break that 250whp.
Old Jun 30, 2006 | 10:09 PM
bboysake's Avatar
How long do you a turbo is good for? Like say this guy with his LS...just stock motor...good EMS... injectors all that crap...what do you think like miles wise?
Old Jul 1, 2006 | 04:41 AM
jweezy225's Avatar
Default Re: (Spec R)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Spec R &raquo;</TD></TR><TR><TD CLASS="quote">I'm rocking basically a greddy kit on my LS....i think 250whp would be feasible given the right upgrades...but by then, it would have equalled the price of a non-CARB exempt kit.
at 6 psi....my b18b1 is making about 9whp/9wtq per pound of boost....with the stock 2" Greddy downpipe, 2.25 exhaust, 2.25 cat...if i get an e-cutout and up the boost...i'm very confident i can break that 250whp.</TD></TR></TABLE>
so at 6 psi your making close to 200whp right? what is an e-cutout? and 6 psi is pretty low dont you think? is your LS motor stock? and what are the "right" upgrades you think that would allow the greddy kit on the LS to reach around 250whp?
Old Jul 1, 2006 | 05:38 AM
pizzaman's Avatar
This page might be usefull. Save yourself some money and build it yourself.
http://www.cse.uconn.edu/~yele....html
Old Jul 1, 2006 | 06:01 AM
jweezy225's Avatar
Default Re: (pizzaman)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by pizzaman &raquo;</TD></TR><TR><TD CLASS="quote">This page might be usefull. Save yourself some money and build it yourself.
http://www.cse.uconn.edu/~yele....html</TD></TR></TABLE>
I love you.
Old Jul 1, 2006 | 06:26 AM
Uncle Ben's's Avatar
Cogent Argument Enthusiast
you should buy my LS turbo kit
http://hondamarketplace.com/zerothread?id=1674155
Old Jul 1, 2006 | 07:01 AM
jweezy225's Avatar
Default Re: (STD ******)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by STD ****** &raquo;</TD></TR><TR><TD CLASS="quote">you should buy my LS turbo kit
why so cheap?
Old Jul 1, 2006 | 07:21 AM
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by jweezy225 &raquo;</TD></TR><TR><TD CLASS="quote">why so cheap?</TD></TR></TABLE>
because i want to get rid of all my **** thats cluttering up my garage, especially since i have no use for any of it anymore.
keving85
Feb 24, 2009 07:12 PM
kirby_lys
Feb 23, 2007 11:57 AM
ACrite3404
Apr 15, 2004 09:07 PM
NastyGsr94
Oct 15, 2003 04:14 PM
V-Grip! Teknic73
Jun 22, 2002 02:28 PM
