Times on the bottle?
......Just put a Zex Kit on order.......just wonderin whut times i can expect, cause right after insall im goin to the track,......alredy got, Intake, Header, Exauhst, Under drive pulley set, Short shifter, CM stage II Clutch, ........
well i rember running a while back a 4door 96 dx at metro and dude was spraying a 75 shot...it was pathetic, he only pulled a bumper on me
so it really varies from set-up to set-up
I've destroyed many modded 'Ludes on the bottle... then again my trap speed was 99.82 mph (awful time though b/c my stock clutch couldn't hold the power and slipped in every gear)... Before the end of the summer, I'll run at the track... and should slip into the 13s...
basic BPUs and a 75hp N.O.S. dry shot, but that was back in Nov 99 when I made that awful 15.1 pass, but at 99.82mph... which should be around 14.1seconds...
but since then i've replaced the ailing OEM clutch with a XTSS setup, Quaife, and a new N.O.S. wet setup... same shot size... gobs and gobs of torque to be found with nitrous in a F motor... ok, i will make it a point this weekend to scan in my dyno sheets from january...
dunreit you sound like your know your stuff when it comes to nitrous(hell, probably even accords). u wanna help me install my nx kit?
[Modified by Razor, 4:57 AM 4/20/2002]
