Will A OBD2 ECU work on a OBD1 motor?
Old Jun 29, 2006 | 11:24 PM
duceducecord's Avatar
Default Will A OBD2 ECU work on a OBD1 motor?
i have a 96 honda accord (OBD2) and a 93 JDM h22a motor inside and i was woundering if i can use an accord or prelude OBD2 ECU?would i have to change the Dist and injectors? to obd2?
Old Jun 30, 2006 | 05:40 AM
soundbomber's Avatar
Default Re: Will A OBD2 ECU work on a OBD1 motor? (duceducecord)
if the car is obd2 then yes, it will technically fit.
but you'll definitely throw some codes because the obd I motor doesn't have a few components that the obd2 ecu will be looking for.
so will it work? yes
will it work well? no
Old Jun 30, 2006 | 12:09 PM
Default Re: Will A OBD2 ECU work on a OBD1 motor? (soundbomber)
ah icic thanks alot
Old Jun 30, 2006 | 01:36 PM
Chuckles99SH's Avatar
You would need an oil pump from an obd2 prelude (has the Cyl position sensor in it) and 97+ distributor and 97+ injectors then the motor should function as a obd2 motor should. There might be more stuff check the FAQ they have a sticky on how to do it.
-GL
Old Jul 1, 2006 | 09:27 AM
Default Re: Will A OBD2 ECU work on a OBD1 motor? (Chuckles99SH)
k kool thanks
my96GSRteg
Apr 15, 2011 11:07 AM
sapper69
Dec 6, 2003 12:30 PM
