92-95 Civic Motor Mount / Engine Damper study???
Old Jun 29, 2006 | 12:01 PM
JEM MotorSports's Avatar
Default 92-95 Civic Motor Mount / Engine Damper study???
OK, here's the deal. We are tryig to figure out which model civics from 92-95 have motor mount bolts which are parallel to one another (level) and which civic models have motor mount bolts which are off set (uneven).
This inquiery is for stock set ups with SOHC only!!! 92-95 civics (all models)
Reason being, we are finding out that after-market engine damper kits may vary from kit to kit...
If you have a stock set up with or without engine damper (J's, NRG, etc.) please post pics of the driver side motor mount..
specify which year and model civic the pics represent.
this info is key in helping manufactures produce a better product.
Thanks,
Here's an example. NOTE: the motor mount bolts are not level to one another.
I am not sure which specific model EG/EJ this is....
NOTE: this engine damper mount has two bolt holes which are even
Note: this damper kits mount has a pair of off set holes even though the pic says EP3 some 92-95 damper kits come with a similar mount.
(...to the hosts off the pics. Your images are being used for research purposes. thanks )
Old Jun 29, 2006 | 12:17 PM
philosofy1's Avatar
Default Re: 92-95 Civic Motor Mount / Engine Damper study??? (JEM MotorSports)
no 92-95 civic or 96-00 civic has it's motor mount bolts are exactly parellel to each other. they are all slightly off to an angle. in the picture posted that is exactly how they are, no matter the model whether eh or ej.
Old Jun 29, 2006 | 12:19 PM
philosofy1's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by JEM MotorSports &raquo;</TD></TR><TR><TD CLASS="quote">
it is clear as day those holes are not even, they are angled. as for the ep civic, though the mounts maybe similar to an eh/ej they are not the same.
Old Jun 29, 2006 | 12:25 PM
Here's a better pic of what we are talking about. You can clearly see how one bolt is higher than the other....
Old Jun 29, 2006 | 12:29 PM
Default Re: 92-95 Civic Motor Mount / Engine Damper study??? (philosofy1)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by philosofy1 &raquo;</TD></TR><TR><TD CLASS="quote">no 92-95 civic or 96-00 civic has it's motor mount bolts are exactly parellel to each other. they are all slightly off to an angle. in the picture posted that is exactly how they are, no matter the model whether eh or ej.</TD></TR></TABLE>
I'm sorry to inform you but your statement is incorrect...
That's why this study is being conducted.
There have been models reported as having level and uneven motor mount bolts.
don't feel bad, we didn't know either...
you learn something new everyday... gotta love this site!
Old Jun 29, 2006 | 12:38 PM
philosofy1's Avatar
you learn something new everyday... gotta love this site! </TD></TR></TABLE>
NO MY STATEMENT IS CORRECT! the bolt is not higher, one sits further up than the other. the bolts are exactly the same height. you must not own a civic?
Modified by philosofy1 at 4:51 PM 6/29/2006
Old Jun 29, 2006 | 12:50 PM
philosofy1's Avatar
http://www.thehondapartsstore....ch=no
click on the link i posted.
honda uses 2 types of engine brackets for their motors(mounts). one has a 2 bolt bracket which usually comes on sohc motors and b16(del sols forgot which years).
and they use a 3 bolt bracket which usually comes on the b18 integras and later b16 del sol's.
so yes, YOU DO LEARN SOMETHING EVERYDAY!
who's misinformed now?
Old Jun 29, 2006 | 01:04 PM
94eg!'s Avatar
#1 Super Guy
Loved
Here is something to help you...
There are two different drivers side mounts for 92-95 Civics. Most use the stamped/welded steel unit (#9) shown in your pictures above. My 94 CX had that same exact mount. After looking up parts on SLHondaParts.com I found that the 3dr Si model of the same year uses a different mount with a flat top where it mounts to the studs. It's similar to the integra mount, and is made from machined billet aluminum (#10). If the Si model with D16 VTEC has the aluminum mount, it's probably pretty safe to assume all civics w/ the VTEC motor have that same mount (EX models for example). You won't know for sure until you do some digging on the parts websites & check out different years & models for yourself to see which part goes with which trim/year. I've given you all the tools, now you've got some work to do...
Old Jun 29, 2006 | 01:11 PM
philosofy1's Avatar
Default Re: 92-95 Civic Motor Mount / Engine Damper study??? (94eg!)
yes that goes back to what i had previously posted:
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by philosofy1 &raquo;</TD></TR><TR><TD CLASS="quote">http://www.thehondapartsstore....ch=no
who's misinformed now?</TD></TR></TABLE>
as for this:
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 94eg! &raquo;</TD></TR><TR><TD CLASS="quote">
the #9 is for the 2 hole bracket and the #10 is for the 3 hole bracket found on the integra's and some civic's.
Old Jun 29, 2006 | 01:25 PM
94eg!'s Avatar
#1 Super Guy
Loved
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by philosofy1 &raquo;</TD></TR><TR><TD CLASS="quote">and they use a 3 bolt bracket which usually comes on the b18 integras and later b16 del sol's.</TD></TR></TABLE>
The #10 mount has nothing to do with Integras, or any B series motor. It is for a SOHC D series VTEC, as is the 3 hole bracket you are refering to in your link...
The Del Sol VTEC (B16) uses mount #9 in the following picture. Not the aluminum mount...
Here is the Del Sol VTEC (B16) block showing the mount uses 2 studs only...
Old Jun 29, 2006 | 01:40 PM
philosofy1's Avatar
yes, the del sol does use that mount. as far as the 3 bolt mount and bracket, they are the same as integras. there is only 2 type of brackets honda uses, no matter what motor DOHC or SOHC. do your homework!
Old Jun 29, 2006 | 01:53 PM
philosofy1's Avatar
http://www.acuraoemparts.com/d...ch=no
here i'll help you with your homework. click on the links.
Old Jun 29, 2006 | 02:33 PM
94eg!'s Avatar
#1 Super Guy
Loved
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by philosofy1 &raquo;</TD></TR><TR><TD CLASS="quote">here i'll help you with your homework. click on the links.</TD></TR></TABLE>
Sorry, but your two links show two different part numbers for each of those 3 hole brackets & it's clear from the two drawings that B & D series brackets are of a different shape. Sorry, but your not schooling anybody. And I won't be copying off of you during test time either...
Anyways, the OP's question has nothing to do with integras. He never mentioned integras, and doesn't want to know about integras. It clearly states 92-95 CIVIC (not even Del Sol). If you plan on helping the man out, don't bring up all this useless information & then argue when someone tries to keep the thread on-point...
The OP has all the info he needs in my first post in this thread eriod:
Old Jun 29, 2006 | 03:09 PM
Relic1's Avatar
straight form honda's parts listing...
50820-SR3-003 - machined aluminum mount - 2 level bolts for mentioned mount
94-97 DelSol SI
94-95 VX
94-95 SI
94-95 EX coupe&sedan (auto&manual)
50820-SR3-J11 - stamped/welded steel mount - 2 uneven bolts for mentioned mount
used on everything except the ones listed for the 003 above (refering to 92-95 civics and 93-97 DelSols (except B-series))
there is also a 50820-SR3-J03 which was superseeded with J11 above
same uneven mounting as J11
came on:
92-93 VX
92-93 EX coupe/sedan
Old Jun 29, 2006 | 03:33 PM
EG-sum's Avatar
how much do these dampers go for/
Old Jun 29, 2006 | 06:59 PM
Relic1's Avatar
60-140 depending on which one and where you buy it.
I have one that I mount on for the track, noticable difference in the way the car responds.
I haven't had a chance to try it on the strip yet though.
To me the car feels alot like it did when I had in a set of motor mount inserts. But a ton easier to remove when you wnat the car to be more forgiving and you don't want the interior to rattle.
Old Jun 29, 2006 | 08:19 PM
Soulless's Avatar
Way to go relic!!
Old Jun 30, 2006 | 12:03 AM
Default Re: (Relic1)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Relic1 &raquo;</TD></TR><TR><TD CLASS="quote">straight form honda's parts listing...
94-97 DelSol SI
94-95 VX
94-95 SI
came on:
92-93 VX
92-93 EX coupe/sedan</TD></TR></TABLE>
YES! YES! YES!... finally someone with the correct RELATED info. THANX (x 100)
Relic you da man!!!
YES! we do learn something new everyday!
RELICS da man and Philosofy recieves the official BONE-HEAD award.
...what 'a jack ***.
yeah, philosofy is probably right about everything else too, I guess I don't own a civic.... HAHAHAHAHA....
as bugs bunny would say, "he don't know me very well, do he?"
philosofy, how do those pro-wings taste? let us know when you get that foot out your mouth.... LOL
Old Jun 30, 2006 | 12:12 AM
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by philosofy1 &raquo;</TD></TR><TR><TD CLASS="quote">who's misinformed now?</TD></TR></TABLE>
You are...
Here's your new avatar....
Modified by JEM MotorSports at 1:58 AM 6/30/2006
Old Jun 30, 2006 | 06:04 AM
mwieczorek43's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by JEM MotorSports &raquo;</TD></TR><TR><TD CLASS="quote">...Philosofy recieves the official BONE-HEAD award.
...what 'a jack ***</TD></TR></TABLE>
Bawahaha! Nicely done
This thread has some very usefull information and needs a bump
Old Jun 30, 2006 | 10:37 AM
philosofy1's Avatar
94-97 DelSol SI
94-95 VX
94-95 SI
came on:
92-93 VX
so what your saying is there is a engine bracket for the hondas that have 2 bolts identically parellel to each other? and that there is a mount that has exactly to holes identically parellel to each other so they bolt up to the engine?
not trying to be an *** hole but, do you have photos?
Old Jun 30, 2006 | 10:57 AM
philosofy1's Avatar
Default Re: (philosofy1)
this is the 2 bolt pattern honda uses, the only one. there is none where the bolts are identically parellel to each other. so back to the question at hand, this is the only one.
this the other one honda uses, it has a 3 hole pattern. now the reason i bring this up is for the dumb *** JEM MOTORSPORT. i was trying to explain that there is only 2 motor mounts regardless of the motor. there is no other 2 hole mount.
yes there is different numbers, of coarse. the only difference in the numbers is the 3 digits in the middle, thats how they distinguish what model you have.
Relic you da man!!!
so *** wipe, i'm not misinformed, my foot is not in my mouth, and next time try not to get you panties all wet when you get excited.
why don't you go watch your F&F and jack off to vin diesel *** HOLE!
Old Jun 30, 2006 | 11:18 AM
Syndacate's Avatar
why don't you go watch your F&F and jack off to vin diesel *** HOLE! </TD></TR></TABLE>
Every time I see you you're arguing with somebody, this time ur arguing with 4 different people in one thread, gotta hand it to ya man... You're worse than me.. How old are you?
BTW: Does your anime avatar make you JDM?
Old Jun 30, 2006 | 11:23 AM
philosofy1's Avatar
Default Re: (Syndacate)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Syndacate &raquo;</TD></TR><TR><TD CLASS="quote">
BTW: Does your anime avatar make you JDM?</TD></TR></TABLE>
oh it's my wet behind the ears friend. how are you doing.
BTW:
1. i usually am not arguing with people.
2. i'm not worse than you because your just a noob that doesn't know what the hell he's talking about.
3. my avatar is not even of a japanese cartoon so how the hell does it make me JDM.
4. i'm alot older than you.
so if you have nothing technical to say, then shut the fu*k up!
oh BTW how are those deers. still juming out at you?
Old Jun 30, 2006 | 11:35 AM
Syndacate's Avatar
BTW:
oh BTW how are those deers. still juming out at you?</TD></TR></TABLE>
And now you're arguing with me that you don't argue with anybody.. Alright, in any event, if you're trying to imply that my civic being totalled due to hitting a deer wasn't actually a deer AFTER looking at the pictures than you really have no idea about any kind of body damage what-so-ever and should shoot yourself ASAP.
Oh yeah, and if you're a lot older than me, then you really act childish and pathetic...so what's your deal, 39 years old, works at wal*mart, lives in his parents' house?
