FS: 92-00 Civic Energy Suspension Motor Mount Inserts
Bought these a while back... sitting in my garage BRAND NEW. $25 + shipping
Designed to provide improved performance by eliminating excess engine movement, which results in unwanted wheel hop due to inferior stock rubber motor mounts. Like all ENERGY SUSPENSION Hyper-Flex polyurethane components, they are impervious to vehicle fluids, road salt and oils (unlike O.E.M. rubber). ENERGY's two piece support insert set is designed to be used in conjunction with the original stock motor mount. The benefit of this insert design is additional strength and toughness, thanks to polyurethane support for the existing rubber part. This quick solution is easy to install and just as simple to remove and return the mount to stock configuration if so desired
no1_suspek
Honda Civic (2001 - 2005)
Sep 21, 2010 01:53 AM
ctr status
May 8, 2006 11:24 AM
