krylon black wrinkle paint
Old Jun 29, 2006 | 09:17 AM
EG type GTR
Guest
Posts: n/a
Default krylon black wrinkle paint
yes i searched and came up with nothing.
anyways, i went to the local pepboys/autozone and they didnt have any vht wrinkle paint and thats why i bought the krylon black wrinkle.
has anybody tried this before? does it match oem quality?
Old Jun 29, 2006 | 09:25 AM
Diet Honda Civic's Avatar
Default Re: krylon black wrinkle paint (EG type GTR)
Make sure you shake it VERY WELL. I used it on my Camaro and it turned out beautiful. Take your time with it and you will be pleased with the results. I was.
Old Jun 29, 2006 | 09:43 AM
B18EG6's Avatar
Default Re: krylon black wrinkle paint (Diet Honda Civic)
here is my experience with it (not as flat as I would have liked; did I do it incorrectly?)
Old Jun 29, 2006 | 09:49 AM
EG type GTR
Guest
Posts: n/a
Default Re: krylon black wrinkle paint (B18EG6)
hmm shiny... did you do it wrong or is that the real finish?
is it high temp? it doesnt say on the can.
Old Jun 29, 2006 | 09:52 AM
racer22's Avatar
I used to paint models and the trick is to warm up the spray with warm water then start painting. It comes out much smother when applying the paint.
Old Jun 29, 2006 | 09:55 AM
Paxil4x4's Avatar
Default Re: krylon black wrinkle paint (aallbbeerrtttttt)
The key is when doing wrinkle paint is prep and patients. The VHT paint can claims 48 hours before its cured. I let mine sit roughly 72 hours and it came out nice.
Old Jun 29, 2006 | 10:30 AM
SkoundrelUSA's Avatar
cute little bastard
Default Re: krylon black wrinkle paint (packthis)
OT: Does it matter if its high temp or not? At Vatozone they sell some Wrinkle Finish paint, but it doesn't say anything about high temp on the can.
Old Jun 29, 2006 | 11:18 AM
B18EG6's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by aallbbeerrtttttt &raquo;</TD></TR><TR><TD CLASS="quote">that pic above doesnt look dry yet, my friend used krylon wrinkle, turned out really flat and nice</TD></TR></TABLE>
naw its dry
Should I try it again? Use heat? Wait for coats to dry completely before reapplying? help meeee
Old Jun 29, 2006 | 11:51 AM
eJone powereD's Avatar
shake the can real well...spray it one thin smooth layer at a time and let each layer dry before adding another layer so that it can wrinkle good...i found that it was best to use a blow dryer between each layer to help the paint dry and wrinkle up
here's my valve cover using the krylon black wrinkle paint...hasnt chipped off yet and the heat hasnt affected it....its rock hard
Old Jun 29, 2006 | 12:09 PM
EeeJayEight's Avatar
Default Re: krylon black wrinkle paint (eJone powereD)
looks nice
Old Jun 29, 2006 | 01:50 PM
mwieczorek43's Avatar
Default Re: krylon black wrinkle paint (EeeJayEight)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by SkoundrelUSA &raquo;</TD></TR><TR><TD CLASS="quote">but it doesn't say anything about high temp on the can.</TD></TR></TABLE>
I use the regular wrinkle-black (non high-temp specific) and have nothing but success. I've done two on my own engines and multiple vc's for friends..
actually my ls' vc has been fine for at least three years (driven 24/7/365). I actually bake the vc after the application is dry, so ignore the previously posted high-temp comment.
I've tried pre-heating to 350, let bake for 5-10 minutes, remove and cool.
or
put the vc in the oven, turn the *** to 350, once the oven hits 350 turn it off, leave the vc in the oven untill the oven completely cools, remove
Old Jun 29, 2006 | 08:21 PM
EG type GTR
Guest
Posts: n/a
how do you mask the lettering? i just finished stripping and sanding my valve cover. help
Old Jun 29, 2006 | 08:27 PM
b16ej1lsd's Avatar
you dont. after the paint cures tape off around the outside of the letters enough so you wont hit it with sandpaper and sand the top of the letters with 180/400 with a small block
you can also put some grease or lipstick or something on it but be carefull you dont get it anywhere you want the paint to stick.
Old Jun 29, 2006 | 08:28 PM
cute little bastard
Default Re: (EG type GTR)
I used masking tape and razored the edges/holes. It was a pain in the *** lol
Old Jun 29, 2006 | 08:30 PM
Paxil4x4's Avatar
I just took a long metal file on mine to bring out the letters.
Old Jun 29, 2006 | 09:14 PM
EG type GTR
Guest
Posts: n/a
i think sanding the letters is the best way to bring it out.
how about the holes? how did you guys cover them
Old Jun 29, 2006 | 09:42 PM
MassScene's Avatar
I found red wrinkle finish from krylon at my autozone. worked awesome. i painted and it wasnt really wrinkling. it then started raining so i had to put it on wet and when it warmed up and dried it wrinkled perfect!!!! but since i had to rush towards the end it got smudged. its a easy fun diy though. ill do it again. i think i will go with black this time though.
Old Jun 29, 2006 | 10:23 PM
GreenEHDriver's Avatar
damn that looks great.
Old Jun 29, 2006 | 10:55 PM
byronl's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by eJone powereD &raquo;</TD></TR><TR><TD CLASS="quote">
they looked like my painted wheels when i applied aircraft stripper on them, makes me want to scrape paint
Old Jun 29, 2006 | 11:29 PM
Frozen E's Avatar
H-T White Ops
I wanna paint my car in wrinkle paint.
Old Jun 30, 2006 | 07:58 AM
hckyNhonda29's Avatar
Default Re: (IslandSi)
What do you use to prep the vc? Just a simple grease remover? Also what grit sand paper needs to be used on the vc before painting?
Old Jun 30, 2006 | 08:02 AM
Default Re: (EJcivic29)
i used aircraft remover and grease remover to strip it of everything on the vc...i then used 1000 grit to sand it and wetsand since my vc was caked with some nasty stuff
Old Jun 30, 2006 | 08:39 AM
JdmLub's Avatar
Default Re: (eJone powereD)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by IslandSi &raquo;</TD></TR><TR><TD CLASS="quote">I wanna paint my car in wrinkle paint. </TD></TR></TABLE>
That made me lol
vc's look nice btw.. i may have to do mine
Old Jun 30, 2006 | 08:52 AM
Thanks for the input
Old Jun 30, 2006 | 08:59 AM
dohcVTECeg2's Avatar
they look so nice done in black
