Doing ITR 5 lug conversion ; Will my stock EG4 drive shafts fit?
I have a EG4 Civic with a D15Z motor. I'm planning to do a ITR 5 lug conversion.
Will the stock Civic drive shafts fit the ITR spindles?
as far as i've ever known and what everyone has always said, B series axles are all the same. if people swap bseries motors into their cars and the EG spindles have never been a problem, why should the d-series axles not do the same for an integra spindle...
hence,
they should be the same splinecount/they will work
hence,
if its a jdm itr 98+ they will NOT fit they are bigger 36 i think instead of 34 or 32. however if its US spec then no problem.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by roma’s GSReg6 »</TD></TR><TR><TD CLASS="quote">if its a jdm itr 98+ they will NOT fit they are bigger 36 i think instead of 34 or 32. however if its US spec then no problem.</TD></TR></TABLE>
So the Euro ITR spindles will fit then?
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by EkSi »</TD></TR><TR><TD CLASS="quote">In order to do a 5 lug conversion you will need a B series motor, you cannot do a 5 lug on any d series</TD></TR></TABLE>
Well, I've just got a euro ITR driveshaft measured vs. a euro D series driveshaft. Both have 26 splines.
So a D series driveshaft will fit a B series spindle. Shouldn't be any different for the US cars.
Why would a Motor have anything to do with the conversion?
Aren't JDM ITR's 4 lug (4 x 114)?
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by PhatBoy5015 »</TD></TR><TR><TD CLASS="quote">
Aren't JDM ITR's 4 lug (4 x 114)?</TD></TR></TABLE>
i dont think 98+ is.
Alfredoem1
Nov 21, 2013 11:47 PM
SPOONfdEK
15
Apr 1, 2005 03:39 AM
.jacob
25
May 13, 2004 08:40 PM
