Sidewalls/Contact patch on Kumho 712's
Old Apr 18, 2002 | 08:52 AM
teg92's Avatar
Default Sidewalls/Contact patch on Kumho 712's
I think everyone here can agree that size for size the Kumhos for some reason tend to have more rounded sidewalls and therefore a smaller contact patch than the next tire. Well I'm looking for tires for my 16x7 rims and am kinda thinking a little cooky...
Here's an exerpt from a thread comparing Azenis to Kumhos... http://forums.clubsi.com/showflat.ph...b=5&o=0&fpart=
The kumho 712s only give approx 6-3/4" of a contact patch due to their rolled sholder design. Compare that the the Azenis pic bellow.
Now look at the same size 205/50 Azenis contact patch!! 7-1/2" wide contact patch!! That's an extra 3/4" of rubber on the road for the same size tire. You can also see that the shoulder is more squared off to the side wall then the 712s are.
---------- end
So what I'm thinking is 215/40-16's are going to be too small in diameter, so next best bet would be 225/40-16's. IMO these should equate to the average 215/45-16. Do you guys think it'll rub or its overkill, or judging by my "exerpt" it might make sense? TIA
[Modified by teg92, 12:52 PM 4/18/2002]
Old Apr 18, 2002 | 09:27 AM
teg92's Avatar
Default Re: Sidewalls/Contact patch on Kumho 712's (teg92)
Hmm no responses...
vtecdc2's Avatar
i think both are good tires, and both have pros and cons...
the kumhos will last longer, but the azenis will give better grip. if u plan on road racing, then go with the flakens.. but for their costs, u cant go wrong either way.
Old Apr 18, 2002 | 09:32 AM
vtecdc2's Avatar
Default Re: Sidewalls/Contact patch on Kumho 712's (HoL Lee SHieT)
hmm.. i'm curious now.. about how long exactly could one see from the azenis..? 50k miles? i just heard they wear faster, but i never found out how much faster
Old Apr 18, 2002 | 09:33 AM
teg92's Avatar
50k?? more like 10-12k at best from what I read...
Old Apr 18, 2002 | 10:00 AM
PatrickGSR94's Avatar
Community Builder
Community Influencer
Active Streak: 60 Days
You won't be able to fit 225's under the fenders w/o some extensive body mods.
Old Apr 18, 2002 | 10:12 AM
teg92's Avatar
Default Re: Sidewalls/Contact patch on Kumho 712's (PatrickGSR94)
I agree that the average 225 will not fit, but given my argument and evidence from that other thread, you don't think its a possiblility?
Old Apr 18, 2002 | 12:26 PM
Community Builder
I think 215's will also rub unless you roll the fender arches.
Old Apr 18, 2002 | 12:34 PM
Acura97GSR's Avatar
Honestly, for daily driving, no track events, how many miles can you get out of the azenis? Is 10-15K with track events or not?
JT
Old Apr 18, 2002 | 12:41 PM
teg92's Avatar
Default Re: Sidewalls/Contact patch on Kumho 712's (Acura97GSR)
I forgot to mention they'd be on a 16x7 40mm offset rim on a DA.
Civicse
Aug 29, 2006 05:57 PM
still
Apr 7, 2006 02:35 PM
paRRRker
Aug 5, 2002 05:14 AM
teg92
Apr 22, 2002 03:21 PM
