4th gen fog light screw replacements?
Old Jun 29, 2006 | 12:48 AM
bboixtc's Avatar
Default 4th gen fog light screw replacements?
basically those three screws that u need to take out to replace the fog light bulb on my fog lights are rusted and the head philips head is nearly stripped because of the rust. i can't find the measurements even here:
http://www.hondaautomotivepart....html
does anyone know where i can get a replacement of those screws?
i went to autozone with one of the screws and its just too small.
i even went to home depot.
Old Jun 29, 2006 | 03:32 AM
ItsSlowYo's Avatar
Default Re: 4th gen fog light screw replacements? (bboixtc)
I ended up getting mine from Lowes or Home Depot I dont remember which. But I just got some screws of the same diameter and then cutting them down to the right size with a pair of dykes. Its not very hard metal, you should be able to cut them down to any size.
Old Jun 29, 2006 | 03:49 AM
bboixtc's Avatar
Default Re: 4th gen fog light screw replacements? (ItsSlowYo)
i can't even find the same screws of the same diameter. i was just at home depot. i know that they obviously must be in MM and not standard measurements.
Old Jun 29, 2006 | 09:03 AM
wstef's Avatar
I used M3 x 18 mm (or 16 ??) - don't remember well, philips head
Old Jun 29, 2006 | 05:38 PM
esedulerp5tenin's Avatar
Default Re: 4th gen fog light screw replacements? (wstef)
dude, i am in the same EXACT pickle as you!!!
i've tried like 7 places, and NONE have screws with threads that small. so right now i have 1 screw holding the bottom plate onto each fog light, haha
Old Jun 29, 2006 | 11:05 PM
kb798's Avatar
I had to go to a speciality nuts and bolts shop to get the proper size.
Old Jun 30, 2006 | 05:59 AM
Default Re: (kb798)
sweet, i'll try that, thanks
D16Z6racing
Apr 14, 2009 12:56 PM
KayOs
Jul 10, 2006 07:54 PM
bboixtc
Jun 14, 2006 11:44 AM
NSX4evr2006
Apr 17, 2006 04:52 PM
spoon805
Sep 1, 2004 08:57 PM
