h22 high compression gasket
Old Jun 28, 2006 | 11:39 PM
Jago's Avatar
Default h22 high compression gasket
wondering if anyone sells a headgasket for an h22 to get the ratio to 11-1 or 11.5-1
Old Jun 29, 2006 | 08:26 AM
Chuckles99SH's Avatar
Default Re: h22 high compression gasket (Jago)
you want just the head gasket to up your compression ratio so high?? wont happen without milling the head, and even with milling you will only raise the compression slightly. to get 11.5+cr you would need pistons or you will be running your valves thru your stock pistons with incorrect pistons.
Old Jun 29, 2006 | 09:41 AM
Jago's Avatar
stock compresion is 10.6-1 going to 11-1 is not much of an increase
Old Jun 29, 2006 | 09:57 AM
bluedlude's Avatar
wow dude......sounds to me like you need to do some research if that was ever a question in your mind.
Old Jun 29, 2006 | 02:31 PM
Rosko's Avatar
Default Re: h22 high compression gasket (bluedlude)
stock headgasket is prolly the thinnest you can buy... around .028" I think.
1SIKZ06
Mar 4, 2009 12:59 PM
kazino42
May 22, 2005 02:41 PM
