how do i get rid of the rear bumper gap?? the SAG
Old Jun 28, 2006 | 08:59 PM
J.nguyen's Avatar
Default how do i get rid of the rear bumper gap?? the SAG
i own a 95 acura integra rs and recently, my rear bumper is now sagging due to an incident at work.. went off the padrack and the rear lip caught onto something and stretched my bumper out and ripped off a ziptie.. zip tied it back on, but now i see a little gap where the bumper meets the other piece..
heres a pic.. sorry u cant really see the gap but up close u can see b/c the right side u dont see it..
i tried taking of bumper and lookin at the bar that goes across.. dunno how to adjust it if u even can..
Old Jun 28, 2006 | 09:01 PM
mike9571's Avatar
Default Re: how do i get rid of the rear bumper gap?? the SAG (JesDM)
Its possible that the mounting points on the side bent. Take the cover off and see if anything is infact bent.
Old Jun 28, 2006 | 09:09 PM
__oversea's Avatar
my 00 gsr rear bumper is sagged too. she is getting old, thats why
Old Jun 28, 2006 | 09:27 PM
TRE_'s Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by JesDM &raquo;</TD></TR><TR><TD CLASS="quote">zip tied it back on,.</TD></TR></TABLE>
Have you tried using the correct mounting hardware? Zipties usually work just fine to hold a bumper on, but when it comes to aligning it and securing it they are useless
Old Jun 28, 2006 | 09:28 PM
FullRaceHonda's Avatar
Default Re: how do i get rid of the rear bumper gap?? the SAG (TRE_)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by TRE_ &raquo;</TD></TR><TR><TD CLASS="quote">
Have you tried using the correct mounting hardware? Zipties usually work just fine to hold a bumper on, but when it comes to aligning it and securing it they are useless</TD></TR></TABLE>
walked that road a million times
Old Jun 28, 2006 | 09:31 PM
jBj's Avatar
jBj
Default Re: how do i get rid of the rear bumper gap?? the SAG (mike9571)
I have this same problem, my 98 spec bumper sags baaad on one side and I think its due to a prevous accident. Im going to pull the bumper and support off and try bending the support with a slight upward angle to put pressure on the bumper, hopefully that will work.
Old Jun 28, 2006 | 09:32 PM
J.nguyen's Avatar
Default Re: how do i get rid of the rear bumper gap?? the SAG (FullRaceHonda)
i dont think ziptie or not would affect the WHOLE line..its not juss one little area, its the whole area.. all the way down past the 1/2 way mark of the bumper..
Old Jun 28, 2006 | 09:33 PM
Desired_Speeds's Avatar
maybe you should try to adjust that metal piece thats right above it
Old Jun 28, 2006 | 10:21 PM
DC2B18cya's Avatar
I have the same problem, but then i took it apart, and I realize that I forgot to put back all the black bumper clips.
Old Jun 28, 2006 | 10:52 PM
J.nguyen's Avatar
Default Re: how do i get rid of the rear bumper gap?? the SAG (DC2B18cya)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by DC2B18cya &raquo;</TD></TR><TR><TD CLASS="quote">I have the same problem, but then i took it apart, and I realize that I forgot to put back all the black bumper clips. </TD></TR></TABLE>
what black bumper clips??
Old Jun 28, 2006 | 11:37 PM
phoshizzle88's Avatar
got anymore pics of the teg **** looks hot
Old Jun 28, 2006 | 11:41 PM
J.nguyen's Avatar
Default Re: how do i get rid of the rear bumper gap?? the SAG (phoshizzle88)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by phoshizzle88 &raquo;</TD></TR><TR><TD CLASS="quote">got anymore pics of the teg **** looks hot</TD></TR></TABLE>
car is under construction at the moment but check my sig for cardomain pics.
Old Jun 28, 2006 | 11:47 PM
nice i like it
Old Jun 29, 2006 | 12:27 AM
RaceMyGhost's Avatar
what side mirrors are those?
Old Jun 29, 2006 | 12:31 AM
J.nguyen's Avatar
Default Re: how do i get rid of the rear bumper gap?? the SAG (RaceMyGhost)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by phoshizzle88 &raquo;</TD></TR><TR><TD CLASS="quote"> nice i like it</TD></TR></TABLE>
thanks. once i get my ace sideskirts on, new headlights, and paint job. it will be done exterior wise..
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by RaceMyGhost &raquo;</TD></TR><TR><TD CLASS="quote">what side mirrors are those?</TD></TR></TABLE>
abs spoon reps
now can we get back to my subject please!! im tryin to make it look clean /w no gaps!
Old Jun 29, 2006 | 01:07 AM
hobo_ken's Avatar
up cause I have the same problem
Old Jun 29, 2006 | 04:10 AM
Kamikaze's Avatar
Bump, I made a video actually and put it up.... Here's my sag...
http://www.youtube.com/watch?v=k9WAwJ2NAWM
Old Jun 29, 2006 | 06:32 AM
juicy.fn's Avatar
i too have the same freakin problem. i think once the bumper is either hit or taken off, it will never be the same when mounted. mine has gone through both and the gap is rideculous!
Old Jun 29, 2006 | 07:18 AM
reno96teg's Avatar
you know those nuts inside the hatch that secure the top of the bumper? you need to loosen those, pull up on the each and retighten. that's how you adjust the gap.
if you're finding that you can't close the gap as much as you'd like, and nothing is obviously broken, you can probably widen those holes to give you more room to pull those bumper bolts further up.
Old Jun 29, 2006 | 08:35 AM
J.nguyen's Avatar
Default Re: (reno96teg)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by reno96teg &raquo;</TD></TR><TR><TD CLASS="quote">you know those nuts inside the hatch that secure the top of the bumper? you need to loosen those, pull up on the each and retighten. that's how you adjust the gap.
if you're finding that you can't close the gap as much as you'd like, and nothing is obviously broken, you can probably widen those holes to give you more room to pull those bumper bolts further up.</TD></TR></TABLE>
hmm, but when i removed the bumper.. i saw the Bar that holds the bumper... mine looks like the left side was OUT more then the right.. dunno if thats how its suppose to be.. ill take a pic..
Old Jun 29, 2006 | 09:44 AM
Arsenal's Avatar
Default Re: (JesDM)
Its very easy to fix, and I use zip ties.
Where the bumper meets that bar, where the holes are. Put washers in between the bumper and the metal bar, then use the zipties to hold them together.
Works very well, have had it done to mine for about 3 years now and no sagging
Old Jun 29, 2006 | 10:03 AM
DSEA2's Avatar
Default Re: (Arsenal)
how is it that you own such a nice car yet you know so little....
Old Jun 29, 2006 | 10:08 AM
redteg96's Avatar
my bumper sags too, this was a good post!
Old Jun 29, 2006 | 10:35 AM
J.nguyen's Avatar
Default Re: (SpoonDC4)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by SpoonDC4 &raquo;</TD></TR><TR><TD CLASS="quote">how is it that you own such a nice car yet you know so little.... </TD></TR></TABLE>
.. this is my FOURTH integra, ive gone through USDM fronts to JDM fronts, NA to Turbocharged, i work at a car shop, where we do oil changes to tires to tranny engine rebuilds etc etc.. so dont assume i know so little about cars.. ur assuming this b/c i ask about a little bumper sag.. iono how u can deduce that from just this one post..
Old Jun 29, 2006 | 10:38 AM
J.nguyen's Avatar
Default Re: (JesDM)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Arsenal &raquo;</TD></TR><TR><TD CLASS="quote">Its very easy to fix, and I use zip ties.
Works very well, have had it done to mine for about 3 years now and no sagging </TD></TR></TABLE>
bumper meets the bar, washers, how would that raise the bumper? would only make it farther out correct?
