clutch release
Old Jun 28, 2006 | 07:24 PM
makavali27's Avatar
Default clutch release
I am having issues wit my clutch release making alot of rattleing, but if i put some force on it with my hands, it goes away, as if it was loose.. what can be the problem.. Is this a serious issue? Also, when i reverse it, I hear a grinding..I have a ls trans and have exedy flywheel and a competition stage 1 6puck clutch. I am reffering to # 3.. picture taken from acuraoemparts.com
Old Jun 28, 2006 | 07:39 PM
gsr dood's Avatar
Default Re: clutch release (makavali27)
ur slave cylinder should sit flush up against it. bleed ur hydo clutch system. if that doesnt work than most likely its the slave cylinder but those things are cheap and easy to replace so it not a big problem.
Old Jun 29, 2006 | 05:14 AM
makavali27's Avatar
Default Re: clutch release (gsr dood)
thx man...Yea i thought of it being the slave cylinder, but i couldn't figure out why that would cause the clutch release to move n rattle..
Old Jun 29, 2006 | 11:18 AM
i-VTEC_do_you's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by gsr dood &raquo;</TD></TR><TR><TD CLASS="quote">ur slave cylinder should sit flush up against it. bleed ur hydo clutch system. if that doesnt work than most likely its the slave cylinder but those things are cheap and easy to replace so it not a big problem. </TD></TR></TABLE>
if that doesn't work you might need a new release bearing, they make noise the same way. with no pressure on them they either make dry bearing type noise or squeel type noise witch goes away when the clutch is depressed.
bassman
12
Jan 26, 2007 12:01 PM
Felt.2
Aug 13, 2006 03:47 PM
LSEGHATCH
May 2, 2006 06:18 AM
dtrtw
Feb 19, 2005 08:03 PM
