B18C5 and OBD1 B16 combo squirting oil!!!!!
Old Jun 28, 2006 | 05:00 PM
92integra-R's Avatar
Default B18C5 and OBD1 B16 combo squirting oil!!!!!
ive been building this engine for a long time. and today was the day i was going to put it in my car. the engine is a used b18c5 block with an used obd1 b16 head. i went to start it started great first try, but then noticed oil squirting with some decent amount of pressure. looks like its coming from between the head and block, but i cant tell right where its coming from... i took these pics to help
you can see where the oil is sitting on the thermostat housing. that corner is just about where its shooting out from! has anyone ever had this problem? i dont know if the b16 head was used for a LS/VTEC build before. im using a 2001 type-r head gasket (OEM).
PLEASE HELP
Old Jun 28, 2006 | 05:43 PM
Circuit Star-29's Avatar
Default Re: B18C5 and OBD1 B16 combo squirting oil!!!!! (92integra-R)
Is the headgasket upside down? Are the numbers on the gasket visable underneath the vtec sel?
This thread should be in the Integra forum or Civic forum...
Old Jun 28, 2006 | 06:30 PM
94rs-turbo's Avatar
yeah sounds kinda like a head gasgate but not for sure u said it was used for ls/vtec where was the tap done at?
Old Jun 29, 2006 | 02:31 AM
Default Re: B18C5 and OBD1 B16 combo squirting oil!!!!! (Circuit Star-29)
i'll have to check to see if i can see the part #. i bought the head from a local speed shop, i dont recall seeing any tapped holes or plugs in the head.
Old Jun 29, 2006 | 03:38 AM
albert.'s Avatar
Whoop Whoop Whoop Whoop Whoop
Default Re: (94rs-turbo)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 94rs-turbo &raquo;</TD></TR><TR><TD CLASS="quote">yeah sounds kinda like a head gasgate but not for sure u said it was used for ls/vtec where was the tap done at?</TD></TR></TABLE>
WTF???
Old Jun 29, 2006 | 01:19 PM
FullRaceHonda's Avatar
maybe you forgot to trq down a headstud? or maybe theres a problem with the deck on the head or deck on the block?
Old Jun 29, 2006 | 02:55 PM
eg_type_r93's Avatar
Default Re: B18C5 and OBD1 B16 combo squirting oil!!!!! (FullRaceHonda)
did you remove the 8mm allen plug fron the head?
Old Jun 29, 2006 | 03:09 PM
AMG's Avatar
AMG
Default Re: (albert.)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by albert. &raquo;</TD></TR><TR><TD CLASS="quote">
WTF???</TD></TR></TABLE>
...Is right with your 3334 posts and join date of 5-25-06? I knew mods messed with % points, but now join date/posts?
Old Jun 29, 2006 | 05:26 PM
Default Re: B18C5 and OBD1 B16 combo squirting oil!!!!! (eg_type_r93)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by eg_type_r93 &raquo;</TD></TR><TR><TD CLASS="quote">did you remove the 8mm allen plug fron the head?</TD></TR></TABLE>
where?
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by FullRaceHonda &raquo;</TD></TR><TR><TD CLASS="quote">maybe you forgot to trq down a headstud? or maybe theres a problem with the deck on the head or deck on the block?</TD></TR></TABLE>
i already replaced the head gasket, my old one was upside down!
so oil isn't squirting out the back!
but know oil is slowly dripping from the flywheel cover!
i swear if i didnt have bad luck, i wouldn't have luck at all!
yes, i know what that means.
Old Jun 29, 2006 | 05:45 PM
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 92integra-R &raquo;</TD></TR><TR><TD CLASS="quote">
where?
There is most likely some residual oil that you see dripping...
Old Jun 29, 2006 | 07:15 PM
projectTeG's Avatar
good luck with the build man...im hoping to see that teggy rolling around town soon.
Old Jun 29, 2006 | 07:44 PM
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Circuit Star-29 &raquo;</TD></TR><TR><TD CLASS="quote">There is most likely some residual oil that you see dripping...</TD></TR></TABLE>
ran it for like 15-20 mins. still dripping
Old Jun 29, 2006 | 10:31 PM
That may be a main seal... Take off the dust cover to the tranny and feel around up there...
Did you clean off the oil from the head gasket mishap?
Old Jun 30, 2006 | 02:45 AM
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Circuit Star-29 &raquo;</TD></TR><TR><TD CLASS="quote">That may be a main seal... Take off the dust cover to the tranny and feel around up there...
Did you clean off the oil from the head gasket mishap?</TD></TR></TABLE>
yeah, i cleaned it pretty good. im pretty sure that something is leaking in there. most likely the rear main or the rear main holder. yes, it was a brand new oem seal!
aRandy
35
May 4, 2011 10:11 AM
shaneburrow
Feb 3, 2008 03:20 PM
shaneburrow
Feb 3, 2008 09:02 AM
92integra-R
Jun 30, 2006 04:37 PM
