Road Racing / Autocross & Time Attack Road Racing / AUTOX, HPDE, Time Attack
koni /GC---EK hatch---How Low???
Old Jun 28, 2006 | 04:47 PM
cheesebox's Avatar
Default koni /GC---EK hatch---How Low???
if i have the ots koni yellows with 425f/500r how low can/should i go without damaging the shocks? how much can you lower the front from stock before you mess up the geometry of the suspension? sorry for the newbie questions but i tried searching w/o any luck
thanks
Old Jun 28, 2006 | 07:27 PM
nonsense's Avatar
Default Re: koni /GC---EK hatch---How Low??? (cheesebox)
I know this isn't an actual answer, but not too low that you're bottoming out. To measure this put a zip tie around the shaft of the shock between the bump stop and the body of the shock. Drive around as you normally would, then come back jack up the car and see where the zip tie is. If it's all the way at (or shoved under) the bump stop then you're too low.
43!
Suspension & Brakes
Jul 24, 2015 11:18 AM
realistpnoy
Jul 7, 2013 04:03 PM
thanh4o8
Suspension & Brakes
21
Jun 26, 2009 12:58 PM
slammin86
Suspension & Brakes
Jan 20, 2009 05:00 AM
kenethcole411
May 12, 2003 07:27 AM
