my brand new shit is leaking oil! HELP!!!!!
Old Jun 28, 2006 | 04:31 PM
92integra-R's Avatar
Default my brand new **** is leaking oil! HELP!!!!!
ive been building this engine for a long time. and today was the day i was going to put it in my car. the engine is a used b18c5 block with an used obd1 b16 head. i went to start it started great first try, but then noticed oil squirting with some decent amount of pressure. looks like its coming from between the head and block, but i cant tell right where its coming from... i took these pics to help
you can see where the oil is sitting on the thermostat housing. that corner is just about where its shooting out from! has anyone ever had this problem? i dont know if the b16 head was used for a LS/VTEC build before. im using a 2001 type-r head gasket (OEM).
PLEASE HELP
Modified by 92integra-R at 8:51 PM 6/28/2006
Old Jun 28, 2006 | 05:29 PM
my95teg's Avatar
Default Re: my brand new **** is leaking oil! HELP!!!!! (92integra-R)
your head gasket is on upside down and backwards... it is covering up one of the oil passages, thus causing oil to squirt out on the back side of the engine between the head and the block
Old Jun 28, 2006 | 05:34 PM
Wayne_Curr's Avatar
Default Re: my brand new **** is leaking oil! HELP!!!!! (my95teg)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by my95teg &raquo;</TD></TR><TR><TD CLASS="quote">your head gasket is on upside down and backwards... it is covering up one of the oil passages, thus causing oil to squirt out on the back side of the engine between the head and the block</TD></TR></TABLE>
That would be my guess as well.
Good to see that everything else fired up right for you though! Sucks that that clean *** block is all dirty now though I take it you had the head milled and block decked right?
Old Jun 28, 2006 | 05:59 PM
akstunt600's Avatar
yup time for a new gasket
btw, use copper spray next
Old Jun 28, 2006 | 06:05 PM
Wayne_Curr's Avatar
Default Re: (akstunt600)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by akstunt600 &raquo;</TD></TR><TR><TD CLASS="quote">yup time for a new gasket
btw, use copper spray next </TD></TR></TABLE>
Not to thread jack, but out of curiosity...what is copper spray?
Old Jun 28, 2006 | 06:16 PM
00IntegrAllmotoR's Avatar
HT Black OPs
Default Re: (Wayne_Curr)
Copper in a can kinda of. It makes for a good seal on all types of gaskets.
Old Jun 28, 2006 | 06:22 PM
poorman's type-r's Avatar
* B A N N E D *
Default Re: (00IntegrAllmotoR)
the head was probably modded for ls v-tec... and the oil passage was plugged... take off the plugged and you'll be good to go... same thing happen to me...
Old Jun 28, 2006 | 07:25 PM
gsr dood's Avatar
Default Re: (poorman's type-r)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by poorman’s type-r &raquo;</TD></TR><TR><TD CLASS="quote">the head was probably modded for ls v-tec... and the oil passage was plugged... take off the plugged and you'll be good to go... same thing happen to me...</TD></TR></TABLE>
DEF
Old Jun 29, 2006 | 02:40 AM
if my head gasket is in right, should i be able to see the part # tab right under the vtec sel? i have to check that! im not sure, but i think i would of noticed a tapped and plugged hole. im thinking my gasket must be in wrong. no, i didnt use any copper spray. yes, i had the head milled. no, i didnt have the block decked.
Old Jun 29, 2006 | 02:54 AM
i checked it, looks like the part # tab is right behind the timing belt cover on the front side. being upside down and backwards would make it like that?
Old Jun 29, 2006 | 05:27 AM
My95SlvrBlt's Avatar
yep, go get a new gasket, and reinstall the head.
The gasket is NOT reusable, and I highly suggest just using gasket, no sense in using copper spray on something that already makes a great seal. Afterall, if it aint broke, dont fix it.
Old Jun 29, 2006 | 11:31 AM
Default Re: (My95SlvrBlt)
yep, i for sure can see the part # tag under the right front corner of the head. (of course not right under it) but close, kinda tuck bent over behind the rear timing cover!
damn, the small details! cant beleave i did that!
Old Jun 29, 2006 | 11:53 AM
Nors's Avatar
Don't worry, I know some guys at professinal shops who have done it... to my brothers car
Old Jun 29, 2006 | 11:55 AM
Wayne_Curr's Avatar
Default Re: (92integra-R)
Poor guy
You learn from your mistakes hehe. After watching your project come along and be stopped dead in its tracks because of this i know for sure i'll pay double attention to that step when putting my motor together
Old Jun 29, 2006 | 12:00 PM
my95teg's Avatar
At this point you are going to have to remove the head reguardless.... so while it is off, make sure that it wasnt tapped for ls/vtec. Also no need to use the copper spray on the head gasket. just install a new one along with new head bolts
Old Jun 29, 2006 | 12:12 PM
Default Re: (my95teg)
how bout a new gasket, and reusing ARP head studs?
Old Jun 29, 2006 | 12:16 PM
Why the expletive is everyone insisting on copper spray?!?!?
Prove to me why a properly level head, and level, decked block wont seal?!?!?!
Old Jun 29, 2006 | 12:41 PM
my95teg's Avatar
That will work as well. also keep in mind that if it was a ls/vtec head... there would be a fitting on the head where the oil feed line would go into. just somthing to think about. just make sure that when you place the new gasket on there that ALL of the oil and coolant passages line up. if i remember correctly the "gold" colored part that mates aginst the cylinder sleeves should face down aginst the block
Old Jun 29, 2006 | 01:57 PM
Wayne_Curr's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by my95teg &raquo;</TD></TR><TR><TD CLASS="quote">That will work as well. also keep in mind that if it was a ls/vtec head... there would be a fitting on the head where the oil feed line would go into. just somthing to think about. just make sure that when you place the new gasket on there that ALL of the oil and coolant passages line up. if i remember correctly the "gold" colored part that mates aginst the cylinder sleeves should face down aginst the block</TD></TR></TABLE>
Thats not necessarily true if someone welded the oil passages then had the head milled...you wouldn't be able to notice at that point where the passages even are =/
Old Jun 30, 2006 | 02:49 AM
i fixed the head gasket problem, its was in upside down! now i got oil slowly dripping from between the engine and tranny. most likely going to have to drop the tranny!
OH YEAH BTW i didnt use any copper spray, just a brand new oem gasket!
Old Jun 30, 2006 | 04:37 PM
DAgsr's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by My95SlvrBlt &raquo;</TD></TR><TR><TD CLASS="quote">Why the expletive is everyone insisting on copper spray?!?!?
Prove to me why a properly level head, and level, decked block wont seal?!?!?!</TD></TR></TABLE>
why not use it?
he says he did not have th block decked. i use it on every build. 3 or 4 bucks for some extra protection.....wont hurt
aRandy
35
May 4, 2011 10:11 AM
djb97ek
Apr 11, 2010 09:00 PM
94_4door
May 12, 2009 06:38 AM
avotegra
Sep 4, 2008 02:59 PM
92integra-R
Jun 30, 2006 02:45 AM
