92 teg gsr -> A/C wont turn on
Old Jun 28, 2006 | 03:50 PM
92integraVTECgsr's Avatar
Default 92 teg gsr -> A/C wont turn on
I have a 92 integra gsr.
Compressor is good. No leaks. System is filled with R12.
I just spent the day at the shop and we found that the A/C will turn on if we put a wire from the negative battery post to the 1 wire coming from the a/c compressor. So the A/C does work, but manually.
I cant figure out why the A/C wont come on when I turn the ****. I tested the relays (4 of them) the A/C Pressure Switch, and all the fuses/relays are good.
what else could be wrong? i just want my a/c working.
thanks.
Old Jun 28, 2006 | 05:37 PM
Teg_Your_It's Avatar
Default Re: 92 teg gsr -> A/C wont turn on (92integraVTECgsr)
I'm having the same problem also, It would be nice to know what's wrong especially in this 107 degree weather.
Old Jun 28, 2006 | 05:41 PM
Wayne_Curr's Avatar
Default Re: 92 teg gsr -> A/C wont turn on (Teg_Your_It)
You know its summertime when the A/C questions come out!
Anyway, was it working before you did your swap?
Old Jun 28, 2006 | 06:33 PM
Default Re: 92 teg gsr -> A/C wont turn on (Wayne_Curr)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Wayne_Curr &raquo;</TD></TR><TR><TD CLASS="quote">You know its summertime when the A/C questions come out!
Anyway, was it working before you did your swap?</TD></TR></TABLE>
it worked last summer fine. then one week it just stopped working.
and i took it out when i did the swap, and just put it back in the other day.
Old Jun 28, 2006 | 06:55 PM
Wayne_Curr's Avatar
Ah, so it stopped working before the swap then?
Old Jun 28, 2006 | 07:17 PM
jared99's Avatar
Is there plenty of refrigerant in the system? The compressor won't turn on unless it detects a certain pressure. Make sure you don't have a leak and the system is really low now. Find a tester and check. If it needs it..you can pay a lot of money to have it retrofitted/recharged at a shop..or just buy some cans of R12 from someone on craigslist or something for about $10-15 per can and charge it yourself.
Old Jun 29, 2006 | 08:14 AM
Default Re: 92 teg gsr -> A/C wont turn on (jared99)
its fully charged. i just took it to the A/C shop yesterday and they charged it, no leaks.
It works when its hotwired, but it wont work normally.
Old Jun 29, 2006 | 09:55 AM
subgeniusdude's Avatar
Maybe either the high pressure or low pressure cut off switches ?
Old Jun 29, 2006 | 10:32 AM
PURPLETERROR aka BIGMATT's Avatar
bump, im having the same problem with my 91 ls
Old Jun 29, 2006 | 10:40 AM
crx_88_si's Avatar
start checking all the relevant wiring. probably a cut wire somewhere or a busted switch.
Old Jun 29, 2006 | 12:50 PM
phoshizzle88's Avatar
Default Re: (crx_88_si)
wire your own switch. lol jk
Old Jun 29, 2006 | 01:59 PM
BrooX's Avatar
I would look into having your a/c system evacuated/recharged. Add in the dye, and recheck the system for leaks.
Is there any codes being thrown?
Old Jun 29, 2006 | 02:01 PM
CASTUDILLO01's Avatar
Default Re: (phoshizzle88)
IF IT WORKED FINE BEFORE THE SWAP THEN HECK FOR BAD WIRING OR CUT WIRES. ALSO FUSES AND RELAYS. BUT I BET ITS YOU PRESSURE SWITCH IS BAB GET ONE FROM THE JUNK YARD. ALSO CHECK THE WIRES/PIGTAILS TO ALL THE RELATED A/C PLUGS ONE MIGHT BE PULLED TO FAR FOR CONTACT.
Old Jun 29, 2006 | 03:31 PM
BrooX's Avatar
Default Re: (CASTUDILLO01)
Take the caps lock off buddy.
Old Jun 29, 2006 | 04:09 PM
Default Re: (BrooX)
i think im just gonna wire my own switch untill i can finish trouble shooting this problem. Relays are good, the Pressure switch is good, the A/C button in the car is good (i tried 2 other switches, and same thing) so i dont know.
ohsnapzafingcu
Jun 10, 2008 04:42 PM
EkDream
Apr 26, 2007 03:35 PM
92civicGA
Mar 20, 2007 05:58 PM
tdc
Jun 27, 2003 08:15 PM
