92 accord ex heat problem
i have a 92 accord ex that on the freeways runs at normal operating temp, but as soon as i pull off and come up to a red light the temp rises almost into the red. if i rev it above 1500 it cools down, but then as soon as i let off it climbs back up again. is it a bad thermostat or what???? any suggestions would help!
Hmm, I had the same problem with my 92 EX. It wasn't my thermostat and Honda thought it was my leaking AC condensor, but it wasn't either. My timing belt and water pump were done at 45k on that car too cause my water pump went. I sold tthe car though for my 95.
Does it do it all the time? That was my problem I couldn't recreate it for someone to look at. It basically did it when I came off the highway and sat in traffic. Once it did it leaving a parking lot.
The radiator cap is possible as well. http://s2000.vtec.net/underhood/radiator_cap.html
If the radiator cap is worn out it will allow fluid to go into the reserve tank easier and thus lowering the effective temperature of your antifreeze. Thus the engine will get hotter when idling. Revving it should increase the pressure thus raising the temp that the fluid is efficient at even with a worn out radiator fluid cap. Those things do wear out and it is the easiest fix I can think of if something is going out.
[Modified by CmptchAV6, 12:08 PM 4/18/2002]
kabhatti
Sep 5, 2008 02:14 PM
diamondwhite50
Jun 17, 2007 09:51 PM
1baddcivicsi
Apr 24, 2006 07:33 PM
