so what in the hell is used to adhere the moisture barrier sheets behind the door panels..
Old Jun 28, 2006 | 08:46 AM
reno96teg's Avatar
Default so what in the hell is used to adhere the moisture barrier sheets behind the door panels??
i asked this ages ago, and no one knew, so i'm trying again... i need to stick the moisture barrier sheets to the door once and for freakin' all, but nothing i've tried works.
- silicone sealants DO NOT work; once it dries, they're stuck to the door but not to the vinyl moisture sheet.
- 3m mounting tape DOES NOT work; it peels right off the door with ease.
i even tried butyl tape. it's sticky as ****, but it does not hold onto the door, nor to the freakin' sheet.
WTF??
i'm tired of this ****. what the hell did honda use? i'm sure i'm not the only person who's had to deal with this crap.
help!
butyl tape:
Old Jun 28, 2006 | 08:48 AM
RaceMyGhost's Avatar
Default Re: so what in the hell is used to adhere the moisture barrier sheets behind the door panels?? (reno
are you talking about that plastic/vinyl sheet that covers up the door holes behind the interior door panel??? like the plastic is being held up by this yellowish glue right?
Old Jun 28, 2006 | 08:53 AM
reno96teg's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by RaceMyGhost &raquo;</TD></TR><TR><TD CLASS="quote">are you talking about that plastic/vinyl sheet that covers up the door holes behind the interior door panel??? like the plastic is being held up by this yellowish glue right?</TD></TR></TABLE>
yep, that exactly.
Old Jun 28, 2006 | 09:05 AM
exvtec94's Avatar
i wanna know also. that stuff is nasty and sticky. in hot weather it starts to run.
Old Jun 28, 2006 | 09:18 AM
reno96teg's Avatar
i'm wondering if i should just scrap trying to adhere that damn sheet and get some dynamat or something.
that "dynamat xtreme " should act as a moisture barrier, no?
Old Jun 28, 2006 | 09:19 AM
iH8RICERZ's Avatar
Default Re: (reno96teg)
ductape? dont know..just throwing out suggestions.
Old Jun 28, 2006 | 09:29 AM
Benard's Avatar
hot glue gun, did it at work all the time
Old Jun 28, 2006 | 09:44 AM
dxasylum's Avatar
I know exactly what you're talking about because my barrier sheet is starting to fall off too. I'm not sure but I believe it is 3M Ultrapro Autobody sealer.
http://www.shop.com/op/aprod-p...eid=3
Honda has this sealant specified for other repairs that I've seen and this sealant has the same tan color as the barrier sealant. You might ask a honda/acura dealer if this would work fine. Good luck!
Old Jun 28, 2006 | 09:59 AM
reno96teg's Avatar
i bet that's it, but at $11 per 5oz, it looks like it'd be damn expensive to seal up the door.
i wonder if regular hondabond is the same thing (expensive too)..
Old Jun 28, 2006 | 10:58 AM
reno96teg's Avatar
thoughts on using dynamat or b-quiet instead?
how well does that crap stick, and does it block moisture?
Old Jun 28, 2006 | 11:31 AM
atg1290's Avatar
Yeah i also need to know in the middle of summer its sticky like gum.
Old Jun 28, 2006 | 11:51 AM
orangebarius's Avatar
Default Re: (atg1290)
try some epoxy glue...that stuff sticks to everything...make sure you clean off both surfaces first so the glue sticks.
Old Jun 28, 2006 | 12:05 PM
Nors's Avatar
clean the surface with alochol first then try whatever you have been trying.
Old Jun 28, 2006 | 12:41 PM
integra15's Avatar
Default Re: (Nors)
Just take it off and cut some dynamat pieces in the same shape. Then stick that son the doors.
Old Jun 28, 2006 | 12:56 PM
atg1290's Avatar
Would weatherstiping glue or contact cement work?
Old Jun 28, 2006 | 01:01 PM
reno96teg's Avatar
Default Re: (Nors)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Nors &raquo;</TD></TR><TR><TD CLASS="quote">clean the surface with alochol first then try whatever you have been trying.</TD></TR></TABLE>
what do i look like, a noob?
all surfaces were cleaned thoroughly.
Old Jun 28, 2006 | 04:07 PM
Nors's Avatar
Sorry but that is a common mistake when working with adhesives.
Old Jun 28, 2006 | 04:52 PM
Echo7847's Avatar
Default Re: (Nors)
Door panel seal adhesive Honda p/n 08712-0003
Old Jun 29, 2006 | 07:20 AM
reno96teg's Avatar
Default Re: (Echo7847)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Echo7847 &raquo;</TD></TR><TR><TD CLASS="quote">Door panel seal adhesive Honda p/n 08712-0003</TD></TR></TABLE>
thanks!
Old Jul 3, 2006 | 05:32 AM
reno96teg's Avatar
finally, after all these freakin' years. thanks, echo. you rock.
i also came across this handy service bulletin: Part #'s and Descriptions for Honda Insulating Products, Adhesives and Sealers, Greases and Lubricants, and Cleaners and Polishes
finally..
myhondasrusty
Jan 26, 2010 07:48 PM
braass91
Jan 4, 2008 09:08 AM
RedKroovy
Nov 3, 2005 12:14 PM
'05 SubyD
Apr 5, 2004 10:41 PM
