FS in WI -- 92 Civic HB and swap parts (Madison)
E-mail krenk000@yahoo.com for details or to take a look.
All pics are on eBay... BUT WILL (AND PREFER) TO SELL LOCAL W/O eBAY. Cash-n-carry rocks!
No reserve on anything. Low starting prices for almost everything (like $0.99-$9.99 for most).
Again, e-mail Ben at krenk000@yahoo.com... don't PM or contact me directly.
1992 Civic HB tub chassis red -- 250002065784
B16 VTEC block JDM w/ internals ran fine -- 250002070580
99-00 Civic Si 15" Wheel -- 250001882844
Cam gears - B-series -- 250001884685
OBD1 engine & car wire harness -- 250001888568
92-95 Civic Dash with NO AIRBAG -- 250001890685
92-95 Civic manual conversion parts -- 250001891463
front lower tie bar -- 250001893380
B series axles & intermed shaft -- 250001894375
92-95 HB hatch & gas filler door release -- 250001896661
15/16" brake master cylinder -- 250001897455
Motor mounts B-series -- 250001898719
APEXi cat-back exhuast and OBX race cat 92-95 HB -- 250001899913
92-95 Civic front lower control arms & poly bushings -- 250001900945
Throttle cable for B-series swap Civic -- 250001901995
Transmission torsion mount B-series -- 250001902946
92-95 Civic hood release latch -- 250002000362
Civic CRUISE CONTROL actuator, brain, hub, buttons -- 250002003356
B-series oil pan gasket (New) -- 250002005325
Genuine Honda B-series B16 head gasket NEW -- 250002006614
Gauge cluster manual 92-95 Civic w/ tach -- 250002008411
B-series fuel rail and fuel line -- 250002009852
Turn, wiper & headlight switches/stalks 92-95 Civic -- 250002012676
AEM B-series fuel pressure regulator -- 250002015332
92-95 Civic CENTER CONSOLE 3-piece black -- 250002017654
Steering Wheel AIR BAG 92-95 Civic black -- 250002020155
ECU P05 -- 250002022014
Exedy 3-puck clutch & B-series lightened flywheel -- 250002026704
92-95 Civic HB interior B & C pillar PANELS gray -- 250002029142
92-95 Civic rear interior panel HB black -- 250002031045
92-95 USDM OEM Civic HB wing w/ brake light -- 250002034640
REAR HATCH 92-95 Civic shaved lock cylinder -- 250002036552
92-95 Civic heater & A/C blower exchanger & housing -- 250002042268
B-series VALVE COVER satin finish -- 250002045448
99-00 Civic Si front calipers -- 250002048220
STAINLESS BRAKE LINES Honda Civic 4- disc -- 250002050087
92-95 Civic TAIL LIGHTS USDM -- 250002051361
92-95 Civic HEADLIGHT HB/coupe right passenger -- 250002052492
Moroso BATTERY BOX and wiring for relocation -- 250002053941
92-95 Civic SHIFT LINKAGE 5-speed D-series -- 250002055454
B-series SHIFT LINKAGE fat bar w/ poly bushings -- 250002057439
del Sol VTEC radiator, hoses, bottle, cap, fan -- 250002060047
92-95 Civic A-pillar panels left and right -- 250002061326
92-95 Civic driver's door glass -- 250002080668
92-95 Civic passenger door and glass -- 250002082999
e-mail krenk000@yahoo.com
Modified by wtfman2 at 11:47 PM 6/30/2006
B-SERIES AXLES!!! how much are you looking to get?!?!?! are u located in Madison???! if so, pick up can be done ASAP!!!!? get back at me!!!
E-mail krenk000@yahoo.com for a phone # and directions. Would like $125 b/c all three are there. However, bring cash and offer something close and you can have them tomorrow.
A D NOH
Jun 24, 2003 04:34 PM
