DOHC ZC CrankShaft Question..?
I noticed my ZC swap had a spun bearing, and the journals are damaged beyond repair. Now, my question is would I be able to use a D16 SOHC crank off a 90 civic SI to replace my damaged crank? Are these crank interchangable? If not what can I use to replace it? Finding a ZC crankshaft is hard being that its a JDM engine.
Thanks, any info would be greatly appreciated!
the DOHC ZC and the D16A6 use the same crankshaft - both the ZC and the A6 used crankshafts with two different diameter front snouts - just make sure the A6 crank you get has the same diameter snout
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by DarkSol97 »</TD></TR><TR><TD CLASS="quote">What do you mean by "snout"?</TD></TR></TABLE>
the part of the crank where the pulley goes on
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 90_EF_Si »</TD></TR><TR><TD CLASS="quote">go find an 89 integra at the local yard and go nuts
So the 89 Integra Crank will work aswell?
</TD></TR></TABLE>So the 89 Integra Crank will work aswell?
91civichatch2571
Oct 20, 2004 09:04 PM
*Boostwerks*
14
Sep 26, 2002 04:29 PM
