GS-R
Old Jun 27, 2006 | 10:47 PM
jmoss1987's Avatar
Default GS-R
I have a 96 GS-R and here are the few mods I have done: DC 4-1 Headers
Cold Air Intake
2.5 inch piping
Magnaflow Cat
I am now stuck. I am not sure what exactly I want to do from here. I am not big on the looks, I want more performace. Any feedback would be aprreciated! Thanks.
Old Jun 27, 2006 | 10:51 PM
desmarais's Avatar
turbo.
Old Jun 27, 2006 | 10:55 PM
-Championship-'s Avatar
76.169.175.137
Default Re: (desmarais)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by desmarais &raquo;</TD></TR><TR><TD CLASS="quote">turbo.</TD></TR></TABLE>
FI
keep going all motor
internals, internals, internals....stock intake manifold isn't helping, blox intake manifold 125 bucks
bg-33p's Avatar
cams, retainers, pistons there's a lot of all motor performance parts you can upgrade. But as said earlier you can also go turbo, but depends on what you're are looking for.
76.169.175.137
Default Re: (project_B18C1)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by project_B18C1 &raquo;</TD></TR><TR><TD CLASS="quote">
FI
internals, internals, internals....stock intake manifold isn't helping, blox intake manifold 125 bucks </TD></TR></TABLE>
not internal but you know what i mean, you can start from there and work your way in
Old Jun 27, 2006 | 11:01 PM
SlamminS85's Avatar
based on his first upgrades, hes ready for turbo... no need to dump all sorts of cash into the GSR when he can get comperable performance with a turbo... this is just based on his first mods being a CAI and then a magnaflow cat
Old Jun 27, 2006 | 11:06 PM
youre_scum's Avatar
What about doing head work? I would tune the entire head to ITR specs including the intake manifold. Im thinking myself about putting ITR or CTR camshafts into a GSR head. Ive read the durations are similar to a racecar but will pass smog and idle fine below vtech crossover. Along with the cams use the ITR dual valvesprings on intake side but not sure on exhaust side. ITR heads are factory ported and polished, so doing that would also benefit. Hope I was some help, the greatest info Ive ever found over Type R series is "best motoring international DVD's= type r documentary". Id rent that along with the book "honda/acura performance by Mike Kojima" you can find that off Amazon.com for like $12. It is priceless information on the endless possibilities on tuning honda motors from super all motor builds to using nitrious, and even a great section on turbo sizing. Well worth the money.
Old Jun 27, 2006 | 11:13 PM
tomlinson619's Avatar
Default Re: (youre_scum)
i would start off by doing cams and skunk2 intake manifold and a simple ECu chip or tune if u a rich boy and got alot of $$ then get JDM ITR pistons and a b16 or ITR tranny..
Old Jun 27, 2006 | 11:19 PM
DBAl's Avatar
well turbo gives you the most power but it would be a waist of money he spent on the header and cai
Old Jun 28, 2006 | 12:15 AM
lVlemphizStylez's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by youre_scum &raquo;</TD></TR><TR><TD CLASS="quote">What about doing head work? I would tune the entire head to ITR specs including the intake manifold. Im thinking myself about putting ITR or CTR camshafts into a GSR head. Ive read the durations are similar to a racecar but will pass smog and idle fine below vtech crossover. Along with the cams use the ITR dual valvesprings on intake side but not sure on exhaust side. ITR heads are factory ported and polished, so doing that would also benefit. Hope I was some help, the greatest info Ive ever found over Type R series is "best motoring international DVD's= type r documentary". Id rent that along with the book "honda/acura performance by Mike Kojima" you can find that off Amazon.com for like $12. It is priceless information on the endless possibilities on tuning honda motors from super all motor builds to using nitrious, and even a great section on turbo sizing. Well worth the money.</TD></TR></TABLE>
the duration of a ctr cam is NOWHERE close to that of a racecar...so thats some false information...moreover...the factory port and polish on the type r shouldnt be that glorified as its VERY mild...if someone wanted real performance out of their gsr..tuning it to ITR specs would be a waste...the ITR head is mild. The main areas that Honda focused upon are the valve seats and bowl not the port volumes. ..hell it doesnt even flow as well as a k series and would you call the kseries a "racecar" ?
Old Jun 28, 2006 | 12:27 AM
1337whp's Avatar
Default Re: (lVlemphizStylez)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by lVlemphizStylez &raquo;</TD></TR><TR><TD CLASS="quote">
the duration of a ctr cam is NOWHERE close to that of a racecar...so thats some false information...moreover...the factory port and polish on the type r shouldnt be that glorified as its VERY mild...if someone wanted real performance out of their gsr..tuning it to ITR specs would be a waste...the ITR head is mild. The main areas that Honda focused upon are the valve seats and bowl not the port volumes. ..hell it doesnt even flow as well as a k series and would you call the kseries a "racecar" ?</TD></TR></TABLE>
lol all this is true, and why would want to tune it to itr specs. thatd make you like a tr. i baught buddy club cams cus i saw a graph proving better gains than ctr cams and itr. last time i checked they werent to much more expensive either
Old Jun 28, 2006 | 12:28 AM
riceball777's Avatar
Default Re: GS-R (jmoss1987)
just go turbo so you can enjoy the car
Old Jun 28, 2006 | 05:19 AM
rkrone's Avatar
go turbo, it's that simple
a few things you can do before that:
fuel pump, injectors, FPR, ecu tune, suspension, .... then turbo
risskybusiness
Nov 9, 2006 03:59 AM
jmoss1987
Jul 28, 2006 01:37 PM
jmoss1987
Jul 26, 2006 12:05 PM
Vtecme92
Jul 31, 2005 08:46 AM
BobGnarly
Mar 25, 2004 11:59 AM
