FS: SUPER SALE!! HYTECH HEADER, TURBONETICS Ball Bearing, BLOX CAMS, SKUNK2, WISECO PISTONS, EAGLE
I have some parts for sale from an all motor setup. Car had ~800 miles on it before everything was pulled. I have decided to work on a new project. Plus other parts that I have around the garage that needs to be cleaned out.
I am located in North Cali, I will ship or do pick up but everything such as shipping/paypal(verified) fees are paid for by the buyer. Do not waste my time with low offers or you will be ignored.
All parts are like NEW with the stated miles unless noted.
<U>MOST ITEMS OBO, PM ME!</U>
(3) Working used IACV's $50shipped
(3) used sets of GSR OEM valve springs, & retainers **miles vary upon each set $70shipped
(3) sets of GSR camshafts **miles vary upon each set $95shipped
(1) brand new in box Energy suspension Civic 99-00 motor mount insert set $30shipped
(1) brand new Type R OEM water pump $95 shipped
(1) brand new in box CraneCam's ignition wire set (yellow sleeves) for D-series, discontinued really thick 11MM! $80shipped
(1) used set of GSR OEM headstuds **62k miles $45shipped
(1) used set of Type R OEM dual valve springs & retainers **26k miles $110shipped
(1) used LS OEM Oil pump **57k miles $35shipped
(1) used Type R OEM Oil pumps **26k $90shipped
(1) used Type R OEM water pump **26k miles $70shipped
(1) set of intake/exhaust BLOX HSL(high speed lift) camshafts $400shipped
(1) set of brand new ARP LS B18A/B headstuds (test fitted & removed) $90shipped
(1) set of 4 Eagle rods for GSR, type H-beam $290shipped
(1) 94-95 stock GSR head w/o dizzy & manifold, complete w/ GSR cams, gears, valve train etc. **62k miles $550shipped
(1) AEM 4inch wide V2 cold air intake for GSR but chopped to fit 92-95 EG Civic w/ B-series **need to relocate overflow tank $130shipped
(2) sets of 4 RC Engineering 310CC injectors OBD1 $SOLD BOTH
(1) Turbonetics T04S/60-1, polished compressor housing, gold anodized backplate(big shaft option), P-Trim, water & oil cooled, .84 tang divided rear A/R, 3" V-band housing **300 miles all bells & whistles $SOLD
(1) set of 4 Wiseco pistons(the best), 81.5mm / 11.8:1 comp ratio $SOLD
(1) set of intake/exhaust Skunk2 red 5-bolt cam gears $SOLD
(1) used GSR crankshaft micropolished **62k miles $SOLD
(1) Hondata S200-Boost w/ everything but data logging $SOLD
(1) Type R throttle body complete w/ all sensors $SOLD
(1) Type R intake manifold complete w/ iacv, etc. $SOLD
(1) 65MM GSR TB w/ sensors $SOLD
(1) HYTECH header with a dent on driver lower runner(needs to be pulled) w/ a pipe welded to the flange(can be removed) $SOLD
(1) set of 4 LS rods with ARP bolts done by machine shop(has JDM Type R pistons included but I wouldn't use them) $SOLD
(1) set of 2 92-95 EG Civic Denji projector headlamps $SOLD
(1) Turbonetics T04B Ball Bearing, polished compressor housing, gold anodized backplate(big shaft option) water & oil cooled, .81 undivided rear A/R, 4 bolt housing **600 miles $SOLD
BLOX HSL CAMS:
CUSTOM AEM CAI EG:
GSR EAGLE RODS:
Modified by rebo0t at 9:24 PM 9/25/2006
BLOX HSL CAMS:
CUSTOM AEM CAI EG:
GSR EAGLE RODS:
