Turbo that will do 400+ whp/ 400ft lbs on a 2.4L with a WIDE torque curve?
Old Jun 27, 2006 | 02:18 PM
.RTErnie's Avatar
Default Turbo that will do 400+ whp/ 400ft lbs on a 2.4L with a WIDE torque curve?
I had a 60trim/t3 .63AR before with a long runner turbo manifold...that netted 28psi by 4500rpms. 2.4L 8:1CR stock head. Im switching to a shorter ram horn manifold that wont loose as much thermal energy and exhaust velocity...and looking for a turbo that will make power sooner and hold the power to 8k. I'd like to make 400ft lbs by 3500 and make 400+whp from 4000-8000....i know it wont be linear, but I'd like to fatten the torque curve and work on turbo response. I'm thinking about a GT28R with an .82 Housing....but Im not sure it will make the power that I need. A 30R is a bit oversized for my goals, but has the response that Im looking for. i have a 3 bar map and standalone, so the PR wont make a difference as long as we dont go over 33+psi
Old Jun 27, 2006 | 02:20 PM
19sec beast's Avatar
Default Re: Turbo that will do 400+ whp/ 400ft lbs on a 2.4L with a WIDE torque curve? (~RTErnie~)
Is this going to be on an SRT-4? K series? H series? S2000?
Old Jun 27, 2006 | 03:10 PM
nonvtecD's Avatar
Default Re: Turbo that will do 400+ whp/ 400ft lbs on a 2.4L with a WIDE torque curve? (19sec beast)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 19sec beast &raquo;</TD></TR><TR><TD CLASS="quote">Is this going to be on an SRT-4? K series? H series? S2000?</TD></TR></TABLE>
SRT4
Old Jun 27, 2006 | 03:13 PM
nowtype's Avatar
GT2817rs if you have the money.
Otherwise using a 50 trim t04e wheel with a smaller stage II turbine wheel might work well.
Also looking into smaller Holsets with a split turbine housing might be a good idea. Split turbine housings have been known to improve spool time dramatically.
Old Jun 27, 2006 | 03:34 PM
99B16Si's Avatar
GT30r
Old Jun 27, 2006 | 04:43 PM
alpha's Avatar
I see it's going to be for an SRT-4. GT30R is going to be your best bet
Old Jun 27, 2006 | 05:59 PM
timg's Avatar
I'd say GT3071R. The GT3076R would be nice, but I doubt if you would get to full boost and have 400+ lb-ft by 3500 rpm. The GT3076R seems to spool a bit later than the GT3071R.
Tim
Old Jun 27, 2006 | 06:07 PM
alpha's Avatar
Default Re: (timg)
Yeah. I missed the part about 3500RPM. The GT30R wont give you 400ft-lbs by 3500RPM. I would suggest trying a GT2871R with different turbine A/R combinations
Old Jun 28, 2006 | 10:21 PM
.RTErnie's Avatar
Default Re: (0x64)
Its an 2.4L Stratus block with SRT-4 Internals in a 1st gen...its all kinds of cluster fucked.
I think the 30r will do pretty well...only problem now is affording one lol.
Old Jun 28, 2006 | 10:51 PM
95BlkGSR's Avatar
Default Re: (~RTErnie~)
dont need to say anything just look
gt3076r rocks
Old Jun 28, 2006 | 10:58 PM
.RTErnie's Avatar
Default Re: (95BlkGSR)
I bet that will carry very well to 8k rpms. Its too bad they didnt dyno it out to 8k.
30r is looking REALLY good. thanks guys
Old Jun 28, 2006 | 11:02 PM
95BlkGSR's Avatar
Stock Block
Stock Intake Manifold and Spacer
Stock Head besides cams...no PnP
tuning baby
mad props to owner
Old Jun 29, 2006 | 11:44 AM
timg's Avatar
Here's a 3076R with a 0.82 a/r turbine housing on a F22C1...
Peak boost was 16 psi around 5000-5500 rpm IIRC dropping to 10 by redline (tuned that way- the injectors were maxed out and couldn't take more boost). This was on pump gas and 9.5:1 compression.
Tim
integlspwr2k
Oct 22, 2007 11:40 AM
BlueSi2k
Aug 23, 2007 01:24 PM
wicked2night
Dec 10, 2006 07:10 AM
want2rally
Sep 15, 2005 04:15 AM
PrecisionH23a
Oct 28, 2002 08:14 AM
