Car consumes wicked amounts of oil yet no drips or smoke while driving
Old Jun 27, 2006 | 11:34 AM
b*saint's Avatar
Default Car consumes wicked amounts of oil yet no drips or smoke while driving
Ring problem or head problem? I heard valve seals can cause you to go through oil and that H22 use oil anyways but a quart every 900~ miles? I guess its time for a rebuild at 146,000 miles.
Old Jun 27, 2006 | 12:44 PM
HxClude's Avatar
Default Re: Car consumes wicked amounts of oil yet no drips or smoke while driving (b*saint)
1 qt every thousand isn't unheard of. Are you leaking from the cam seal too? (when you pop the hood, check left side of the valve cover, where it meets the cylinder head, especially closer to the upper left corner.) Every Prelude leaks there until you replace the cheap *** plastic seal with an aluminum/triple o-ring seal from Golden Eagle or STR.
My Lude has 41k miles and goes through 1 qt every 1000 sometimes.
Old Jun 27, 2006 | 12:48 PM
b*saint's Avatar
Default Re: Car consumes wicked amounts of oil yet no drips or smoke while driving (HxClude)
Yea it is. Nice call. Gonna replace it this week.
Old Jun 27, 2006 | 02:03 PM
HxClude's Avatar
right on.
that should help out a little bit over time. you may want to consider getting a new valve cover gasket too considering your mileage/age and make sure you have some Permatex gray or Hondabond on hand.
here's a good write-up with pics if you need it, including the order you should torque the bolts:
http://www.mdpreludeclub.org/f...64&hl=
1997accordlx
Jan 7, 2010 12:32 PM
sawedoffcoupe
Apr 7, 2008 04:02 PM
bresk8r87
Jan 6, 2006 01:59 PM
vtec-adykt
10
Sep 16, 2005 07:59 AM
hitop
Jan 28, 2003 08:38 PM
