(SEARCHED)*****B16a2 Vs. Poorman's Type R Boosted?????????*****
Ok I blew my Boost Ls set 2 days ago. As Of Now I have a Complete B16a2 head. So Im just going to buy a complete Block and retune. What I want to know is which will make more power and be safe.
B16a2 Stock Boosted Or Poorman's Type R Boosted????????????
My Stock Ls made 267hp on 12psi and I really would like to be at 300hp with a different set up. Im Not really sure which will make power.
poormans type r ='s b18c (gsr) bottom end and a b16 head or a type r head.... and for the politically correct people, the right compression and cams, etc for that
But for your sake, i would get the b18c bottom end if you could over the 1-6...
if you blew an LS at 250 WHP chances are it was improperly tuned, and a GSR block isn't going to fix anything. My advice would be do an LS/VTEC setup and get it properly tuned with the $$$ you save over a GSR shortblock.
First off, what part went boom?
GSR bottom ends are much stronger and you have the addition of oilers that your LS currently doesn't have. So first off, how high to you honestly rev. the engine. Anything over 7k, grab the GSR.
I'm finishing a build on a GSR/B16 setup and plan to push 550hp threw it.
When you say it was tuned...how exactly was it tuned and what kind of monitoring equipment and computers do you use?
Im using Hondata S200 for tuning. I was tuned at 12 psi. I turned the Boost up to 16psi and never ran over 7k. The Ls swap was bought from a Shop that didnt know the milage. I had it boosted for 6 months. And was Tuned By Stoney at Velocity Performance in Dallas, Tx.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by fracas »</TD></TR><TR><TD CLASS="quote">Smart guy!!! I was tuned. I turned up the Boost and it went BOOM!</TD></TR></TABLE>
...and you're making snyde remarks about someone else's intelligence?
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Armed Ferret »</TD></TR><TR><TD CLASS="quote">...and you're making snyde remarks about someone else's intelligence?
Funny isn't it?
</TD></TR></TABLE>Funny isn't it?
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by XSIintegra »</TD></TR><TR><TD CLASS="quote">how high to you honestly rev. the engine. Anything over 7k, grab the GSR. </TD></TR></TABLE>
You can rev an LS bottom just as high as a GSR bottom end.
...Just get ARP rod bolts.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by D-Rob »</TD></TR><TR><TD CLASS="quote">
...Just get ARP rod bolts.</TD></TR></TABLE>
exactly
get the gsr block and reuse your LS crank if it's still good.
2mm longer stroke = more tq
exactly
get the gsr block and reuse your LS crank if it's still good.2mm longer stroke = more tq
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by fracas »</TD></TR><TR><TD CLASS="quote">Im using Hondata S200 for tuning. I was tuned at 12 psi. I turned the Boost up to 16psi and never ran over 7k. The Ls swap was bought from a Shop that didnt know the milage. I had it boosted for 6 months. And was Tuned By Stoney at Velocity Performance in Dallas, Tx.</TD></TR></TABLE>
did you get any track times with it before it popped? do you know your race weight?
a friend of mine has similiar numbers but doesnt want to take it to the track
-SP
-SP
fracas
Jun 30, 2006 09:26 AM
fracas
25
Jun 28, 2006 08:29 AM
