jdm p30 AT ecu work with a '00 b16a2 on 96 civic?
as the title says. just opened the ecu case and found the "74HC373" IC is there. so i was assuming its a AT ecu. will this work with the current setup i have? '00 b16a2 motor, 96 civic running obd2a-obd1 jumper harness.
is this why i'm getting a code for oxygen sensor all the time?
EDIT: ecu reads 37820-p30-010
