brake light problem! help!
Old Jun 27, 2006 | 05:39 AM
charms119's Avatar
Default brake light problem! help!
i have a 93 eg hb...and the problem i have is that the brake lights are always on even when i turn car off the car. dont really know the problem of this thats why im here for some help from my fellow h-ters. my cars battery died the first time i realized that the brake light was the problem. if any of guys can give me some advice on fixing this problem, it'll be a big help to me. thanks
Old Jun 27, 2006 | 07:36 AM
littleredcivic's Avatar
your brake switch right by the pedal is most likely stuck, defective, or out of adjustment.
Old Jun 27, 2006 | 08:42 AM
RedEj8's Avatar
Default Re: (littleredcivic)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by littleredcivic &raquo;</TD></TR><TR><TD CLASS="quote">your brake switch right by the pedal is most likely stuck, defective, or out of adjustment. </TD></TR></TABLE>
This happend to my friends DA Teg.. There was a little rubber piece on the pedal that the brake switch touches that had fallen apart, just needed a new rubber piece.
Old Jun 27, 2006 | 10:08 AM
eg8civic93's Avatar
Default Re: brake light problem! help! (charms119)
You can change the rubber under your brakes pedal. Simple fix.....any non conductor can be used.
Old Jun 28, 2006 | 10:00 PM
charms119's Avatar
Default Re: brake light problem! help! (eg8civic93)
thanks for the help...ill try fixing the problem today....thanks
yoni_69
Apr 12, 2011 01:21 PM
kornkid21792
Jan 21, 2010 03:27 AM
gsrsuperman
13
Jul 21, 2008 10:20 AM
khaperey
Aug 23, 2006 05:18 PM
