Installing a Header not sure
Old Jun 27, 2006 | 05:07 AM
TheAccordGuy's Avatar
Default Installing a Header not sure
I just brought a new header for my prelude and I was wondering can I simply just unbolt the old header and simply bolt the new one on and nothing else. Do I need to buy a special type of sealant or gasket, everything should come with the header right. I brought a greddy 4 2 1 2 piece header. Is there a special way to unbolt, like a pattern or something anyone know the torque spec as well.
Old Jun 27, 2006 | 05:30 AM
Lewdin' Incognito's Avatar
Default Re: Installing a Header not sure (TheAccordGuy)
It should have came with 3 gaskets, but yeah - other than that it should just bolt right up.
"Course, just because it should doesn't mean that it always does.....good luck.
Old Jun 27, 2006 | 05:41 AM
CD5 Jeebies!'s Avatar
From: Free bullets if you find me sucka, Washington
I'd go to a muffler shop and have them do it......but if you have the tools
I don't remeber the tq specs..but if I was you spray some copper sealer on all the gaskets and let them sit....that will make em stronger and less likely to desinegrate and make annoying ticking noises like mine does
Old Jun 27, 2006 | 06:04 AM
esedulerp5tenin's Avatar
Default Re: Installing a Header not sure (I got the CD5 Jeebies!)
it should be fairly easy and straight forward. i would just suggest to soak the nuts/bolts in PB blaster the night before, or at least a coupla hours before hand, just to make them easier to come off.
i can't member the tq specs, but make 'em tight enough
Old Jun 27, 2006 | 08:24 AM
tcontesh's Avatar
you should be fine if you have the tools and are capable of doing it. you will have to go back and tq down every bolt after about 500 miles due to heat expansion, i know alot of people who dont follow this step and all they do is complain about exhaust leaks. so just do it right and you will be all set
MajinB
Honda Civic (2001 - 2005)
Apr 20, 2006 03:53 PM
SpeedFreak77
Mar 26, 2006 10:08 PM
Project_ED8
Mar 10, 2004 11:36 AM
ebelp
Jul 29, 2003 10:21 AM
geminis2k
Mar 3, 2003 02:45 PM
