What do you think of Skunk2s front & rear camber kit and Test Pipe?
Old Jun 27, 2006 | 03:13 AM
civicdohc's Avatar
Default What do you think of Skunk2s front & rear camber kit and Test Pipe?
im thinking of buying a skunk2 front and rear camber kit and test pipe. what are your opinions of skunk2 camber kits and test pipe. anyone suggest other brands to buy for the camber kit or the test pipe?
Old Jun 27, 2006 | 06:16 PM
stumpyf4's Avatar
Default Re: What do you think of Skunk2s front & rear camber kit and Test Pipe? (civicdohc)
Front camber kit is what is being copied over and over. 1st gen Skunks are the same as Blox or Omni. 2nd Gen arms have improved clamping of the ball joint however the adjusting screws are harder to reach. I'd buy the Omni or Blox and modify with better screws and ball joint boots. If you have lots of cash the SPC control arms look much better and have a caster adjustment.
Skunk2 rear camber kit had issues with bushings shifting, now has been corrected. I'd go with a different brand such a SPC, pretty much the same thing but I haven't heard any issues with the SPCs.
Skunk2 test pipe is nothing special. I'd go with the Omni one since it's adjustable in both length and clocking.
Old Jun 27, 2006 | 06:22 PM
__oversea's Avatar
Default Re: What do you think of Skunk2s front & rear camber kit and Test Pipe? (stumpyf4)
not only that. 2nd gen SK2 camber kit has plate over adjust bolts, for prevent bolts sliping. however, people have problem hitting engine bay that cause bent, hole.
ingall kit might be better, imo
denisq6
Honda Civic (2006 - 2015)
May 6, 2012 09:26 AM
aeros
Northeast (Sales)
Jun 22, 2009 05:19 PM
civicdohc
Suspension & Brakes
Jun 28, 2006 01:32 PM
cichlid
Apr 4, 2003 03:32 PM
AMG
Dec 6, 2002 01:36 AM
