URGENT: Need to make sure I installed my AEM CAI correctly?
basically my problem is that I am not sure if i did the right thing.......i took the stock airbox out and eveyrthing..and i used the hose they gave me to connect the hole on the throttle body to the intake manifold..however when i disconnected the old hoses...there is green fluid dripping out.....
so did i do the right thing by connecting the two hole with one hose....??
thanks so much
also..there are stuff dripping fomr my bottom of my car.....and i saw one hose that i have no idea what it is..it's right next to the suspension....
thanks guys
thanks so much
thanks guys
You don't need to change any hoses from the intake manifold or throttle body.
The only thing you need to change is the hose from the intake to the valve cover.
ShinotakuX
May 14, 2008 09:55 PM
