what's a good tire size for the 16" jdm itr wheels?
Old Jun 26, 2006 | 06:34 PM
tranzvision's Avatar
Default what's a good tire size for the 16" jdm itr wheels?
I just purchased a set of the 16" jdm itr wheels and was wondering what tire size would be best for them? I'm not really looking for a beefy set of tires so I came up with these options..
So far I have these choices:
205-40-16
or
205-45-16
Thanks in advance!
Old Jun 26, 2006 | 06:43 PM
pennies_hatchie's Avatar
Default Re: what's a good tire size for the 16" jdm itr wheels? (tranzvision)
205/45/16
Old Jun 26, 2006 | 06:45 PM
Default Re: what's a good tire size for the 16" jdm itr wheels? (pennies_hatchie)
cool sounds good..
Old Jun 26, 2006 | 07:33 PM
01-0720's Avatar
oem size is 215-45-16
Old Jun 26, 2006 | 08:03 PM
nsxtasy's Avatar
H-T Order of Merit
205/45-16 or 215/45-16. Either one will work. Both are within 1 percent of the stock outer diameter and neither one should rub.
Decide on what kind of tire you want to buy, and see what it comes in. Some tires come in 205/45, and others come in 215/45.
205/40-16 is too small. That's for pre-'96 Civics.
Old Jun 27, 2006 | 03:54 AM
Default Re: what's a good tire size for the 16" jdm itr wheels? (nsxtasy)
cool thanks for the advice...I think i'm going to stick w/ the 205-45-16
Old Jun 27, 2006 | 09:56 PM
MiraiZ's Avatar
215 = better traction
Old Jun 27, 2006 | 10:12 PM
realis9's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by tranzvision &raquo;</TD></TR><TR><TD CLASS="quote">cool thanks for the advice...I think i'm going to stick w/ the 205-45-16 </TD></TR></TABLE>
that is what i have more tire choices
Old Jun 30, 2006 | 04:48 PM
nsxtasy's Avatar
H-T Order of Merit
Default Re: what's a good tire size for the 16" jdm itr wheels? (MiraiZ)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by MiraiZ &raquo;</TD></TR><TR><TD CLASS="quote">215 = better traction</TD></TR></TABLE>
Not necessarily. The type of tire (make and model) is much more important determinant than the tread width. A stickier tire in 205/45 has more traction than a tire that's not as sticky in 215/45.
Old Jul 3, 2006 | 12:20 PM
jep's Avatar
jep
255/60/16 fullrace style
Old Jul 3, 2006 | 12:35 PM
Sukebei Oni's Avatar
Default Re: (jep)
I run a 215/40/16 on my JDM 16's
works great for me. But I have a GSR. Since JDM R have lower gear ratios than me the bigger OD works for them. But I didn't want to go bigger OD than stock GSR. the 215/40/16 is slightly smaller that OEM GSR. So in a way, its like lowering the gear ratios. Just a tiny bit though.
Old Jul 3, 2006 | 02:00 PM
Black R's Avatar
25 Year Member
we're using the oem usdm itr tranny on the white itr and jdm 16's. 220whp.
the oem jdm 215/45/16 is excellent and we've been very pleased with advans in that size, but given the option, we decided to go a little wider: 225/40/16.
the car is quite low and doesn't rub.
yellow_ek
Dec 3, 2005 04:38 PM
jonyb
Nov 10, 2003 11:44 AM
JDM TypeR 307
Oct 4, 2003 04:58 PM
scooter
Jan 1, 2003 06:57 PM
Ryuji
Oct 10, 2001 01:07 PM
