any advantage to h23 over h22a?
0.10L of more displacement?
Honestly, there is no advantage. The swap is bolt in, and if you're lucky the VTEC wires are already there.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by e16prelude »</TD></TR><TR><TD CLASS="quote">dohc vtec performance seems the way to go.
I think everyone knows that for the past, oh....14 years or so now.
Let me know if you have any questions on the swap. I've swapped an H22a into the Si before (blew up the H23a1), and it was pretty simple.
The performance factor was definitely worth it.
H22 is a easy choose, but my only word of advice is do the manual timing belt tensioner before installing it, and if you plan on pullin the balancing shafts, that too.
Here are a few links if you not sure what I'm talking about:
Timing belt tensioner swap:https://honda-tech.com/zerothread?id=549516
Balnancing shaft info:https://honda-tech.com/zerothread?id=503372
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by oranginal »</TD></TR><TR><TD CLASS="quote">isn't the h23 safer/better to boost, i remember reading that somewhere.
i have an h22 so i wouldn't really know, just a maybe
Not really. The H23 still has FRM reinforced cylinder walls, so you still have to sleeve it before running forged pistons. There also aren't any oil squirters.
depending on what you want and what you are willing to do yourself then I would vote for a mildly built H23.
H22A1 pistons
Cams, springs, retainers
Tuned ECU
I/H/E
will produce the same power as a stock H22 swap but with more torque. I am biased though. Your rebuilt H23 = less expensive street monster.
Pirate
H22A1 pistons
Tuned ECU
I/H/E
Pirate
I used to have a 92 Si w/ H23. Despite vtec and shorter gear ratio's, I miss the low end and esp mid range of H23. The top end (it is dead past 5500rpm) is really where it suffers. A good set of cams will really go a long way with this engine.
I say follow Pirate's suggestion. Having the torque is really nice on the street.
the best part of an h23 is they can hold boost way better then an h22, i had an h22 turbo hatch and it sucks only 5psi, it went 12's but still i wanted more BOOST! so i guess if ur looking to go that route then you might think differnt bout goin h22, but if u jsut wana go all motor with bolt ons, either the h22 is good or a frankenstien motor would be good to, or the euro r motor even tho there expensive ive heard great things bout them!
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by cbr900rr_uponone »</TD></TR><TR><TD CLASS="quote">the best part of an h23 is they can hold boost way better then an h22, i had an h22 turbo hatch and it sucks only 5psi, it went 12's but still i wanted more BOOST! so i guess if ur looking to go that route then you might think differnt bout goin h22, but if u jsut wana go all motor with bolt ons, either the h22 is good or a frankenstien motor would be good to, or the euro r motor even tho there expensive ive heard great things bout them!</TD></TR></TABLE>
youre a douche
youre a douche
The H23 aint too bad of a motor. I just fart around with my stock one and have plenty of fun with it. You will walk stock 240's and Celicas (GTS excluded) own SOHC civics, accords, and ludes. And you will give LS integras, non type S RSX's a run for their money (especially if they can't drive). With that in mind I can only emagine how fun a mild to well build H23 or stock H22 would be. Either way I think you have alot of options at your finger tips.
Don't listen to this garbage.
H22s and H23s both have great potential. The deciding factor is how much research you do and how much $$$ you have to spend.
^I usually get too caught up in picking out the bad grammar in those kinds of posts to really hear them out. LOL
I can tell you not to get so many big ideas in your head for starters. If you want to go through with something with the current amount of knowledge at your disposal, make it simple. However, if you are as stubborn as I am, you'll learn more before doing anything. Hell I still am and probably will for quite a while.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by mojo_stevo »</TD></TR><TR><TD CLASS="quote">Dude hawkeye... your gallery is empty bro, totally got my hope ups too. Party foul man, par-t foul.</TD></TR></TABLE>
That gallery link is only there because I wanted to support H-T and I bought the $5 membership thing and they just stuck that link under my name.
My car is pretty ugly anyway.
dude every single post you have made so far on Honda-Tech.com have been garbage.
research and know your **** or STFU
You're going to get a hundred different answers to that question...you need to decide for yourself what you want to do.
ok, no obvious choice. im just trying to get some info and opinions from people that have more experience and knowledge than me. its what i got, thanks.
