Honda Civic (2001 - 2005) Coupe / Sedan / Hybrid (Includes Acura EL)
2001 Civic DX AT won't START!!! HELPPPP!!!
Old Jun 26, 2006 | 09:44 AM
R.S.AKIMOTO's Avatar
* B A N N E D *
Default 2001 Civic DX AT won't START!!! HELPPPP!!!
OK when I try to start the car the D the D1 & D2 all light up green even thought the car is in PARK. The motor turns over and sounds like it wants to FIRE but nothing...just cranks...
ANYHELP WOULD BE GREAT!!
Old Jun 26, 2006 | 09:49 AM
Miracle's Avatar
Default Re: 2001 Civic DX AT won't START!!! HELPPPP!!! (R.S.AKIMOTO)
im assuming its either not getting fuel or spark.
If it was the security key system thingy, the im not thinking it would crank.
Any Check engine lights???
Old Jun 26, 2006 | 10:52 AM
* B A N N E D *
Default Re: 2001 Civic DX AT won't START!!! HELPPPP!!! (Red_EMII)
The check engine light is on but I don't have a scanner to check it. The WEIRD thing is that the D, D1..ext all light up even tho the car is in PARK. Does that make since?
Old Jun 26, 2006 | 10:55 AM
Miracle's Avatar
not really, but your best bet is to go rent an OBD scanner from AutoZone, O'Reilly's, or Advance and get the code.
Youll narrow your choices down by 1000x if you get the code its throwing.
Electrical problem maybe too?
Old Jun 26, 2006 | 11:15 AM
* B A N N E D *
yep I think its electrical too. Didn't know you could rent the scanner. ROCK ON!! We do not do any automotive repair work here so it didn't make since to go buy a new scanner if not needed!!
Whats the best way to check spark & fuel on that motor?
Old Jun 26, 2006 | 11:18 AM
Miracle's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by R.S.AKIMOTO &raquo;</TD></TR><TR><TD CLASS="quote">yep I think its electrical too. Didn't know you could rent the scanner. ROCK ON!! We do not do any automotive repair work here so it didn't make since to go buy a new scanner if not needed!!</TD></TR></TABLE>
Well, you can at the ones around me, I think AZ and Advance rent them out, I KNOW O'Reilly's by me does, I used to manage one here in Clarksville.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by R.S.AKIMOTO &raquo;</TD></TR><TR><TD CLASS="quote">Whats the best way to check spark & fuel on that motor?</TD></TR></TABLE>
Pressure test the fuel lines at the Rail,
And pull the coils and the them like you would any other plug im assuming to check if its getting spark. But in any case, pull that code first and foremost, because you may not have to do any of that.
It honestly sounds like something purely electrical to me.
Old Jun 26, 2006 | 11:27 AM
* B A N N E D *
I think electrical too!
Old Jun 26, 2006 | 04:20 PM
* B A N N E D *
any other ideas?
Old Jun 26, 2006 | 05:48 PM
xproductionz's Avatar
similar thing happen to one of my customers that came in the shop.. come to find out it was a fuse that blew... check all fuses... if one is blown... reset the ecu and turn it on again
Old Jun 27, 2006 | 08:29 AM
* B A N N E D *
Default Re: (xproductionz)
Which fuses should I check. I went over the majority of the one under the dash and the ones under the hood unless I am missing something...???
I think I'm on the right track with that info tho...
THANKS
Old Jul 3, 2006 | 09:39 AM
* B A N N E D *
Default Re: (R.S.AKIMOTO)
wow...this things still not starting!!
ANY MORE SUGGESTIONS???
Old Jul 5, 2006 | 09:21 AM
* B A N N E D *
AWWWWW...
still nothing. I've check all the fuses and RELAYS under the the dash and under the hood and nothing seems to be bad or out of place. Fuel pump fuse & Ignition coil fuses both light up while the car is trying to turn over...but NO FIRE....
I TOTALLY think the problem has something to do with the fact that the D,D1...D2 all light up even though the CAR is in PARK. The P for park is also lite up.
ANYMORE suggestions??
Is there fuses or relays for the transmission??
Are there more fuses or relays other than the ones under the hood and dash??
Old Jul 5, 2006 | 04:11 PM
* B A N N E D *
no diagnostic guru out there to help...?
Old Jul 5, 2006 | 04:48 PM
toyomatt84's Avatar
Sanji
Have you checked the CEL code? Because that might provide you with some answers.
Old Jul 7, 2006 | 12:37 PM
* B A N N E D *
Default Re: (toyomatt84)
NO CEL...?
That's...way I'm confused!
Old Jul 11, 2006 | 01:31 PM
* B A N N E D *
nothing yet huh?
Old Jul 11, 2006 | 08:07 PM
toyomatt84's Avatar
Sanji
Have you taken it to Honda yet? Because if you haven't, I'd suggest having them take a look.
Old Jul 12, 2006 | 01:18 PM
* B A N N E D *
got to get it started first...
Old Jul 12, 2006 | 01:29 PM
Miracle's Avatar
Youve got me man. faulty wiring is all I can think.
It IS throwing a DTC though right? if so, thats the key to figuring out the problem.
Modified by Red_EM2 at 7:11 PM 7/12/2006
Old Jul 12, 2006 | 02:44 PM
toyomatt84's Avatar
Sanji
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by R.S.AKIMOTO &raquo;</TD></TR><TR><TD CLASS="quote">got to get it started first...
It's 50bux to get a tow truck to come pick it up, and if the car were still under warranty, then it'd be up to the Dealership to come pick it up.
chieftaco
Dec 25, 2010 02:01 AM
LScivic_wpg
May 27, 2006 10:10 PM
Mandeep
Jul 17, 2005 11:33 PM
mhng
Apr 23, 2005 06:44 AM
